Gimpville Kontiki Breakdown
Korhon
Hi all.
Just wanted to share some of the work we did for the Norwegian movie Kon-Tiki.
All shots except the crowd was rendered with Mantra, so there is a lot of Houdini work involved.
We used HOT for all our cg oceans, and we wouldn't have any good ocean soulutions in Houdini without HOT.
So a big thanks to Drew Whitehouse for creating HOT!
All shots was made in H11 except two whale shots. These shots were done in H12 'cause we needed to do high-res flip-simulations around the whales as they break the ocean surface.
Also a big thanks to SideFX for creating a kick-ass software that solves every problem you throw at it ;)
Visual Effects by:
Gimpville AS
Studio Manager:
Torgeir Sanders
VFX Producer / Supervisor:
Lars Erik Hansen
On set VFX Supervisors:
Lars Erik Hansen
Torgeir Sanders
Christian Korhonen
Modelling / Sculpting / Texturing Artists:
Jan Svalland
Christer Bjørklund
Simon Dahle Nyhus
Andreas Lønø
Petter Burhol
Eryk Pajewski
Alexander Bjune
Previz Artists:
Alf Martin Løvvold
Kjetil Haalnd Kulander
Andreas Lønø
Match Moving:
Kjetil Haaland Kulander
Animators:
Einar Rafoss Dunsæd
Atle Blakseth
Matte Painter:
Olve Askim
Grant Regan
Houdini Artists:
Christian Korhonen
Ole G. Eidsheim
Jan Svalland
Severin Mathiesen
Compositing Artists:
Jan Svalland
Severin Mathiesen
Heidi Dahle
Edited by Korhon
Thanks all! :)
Pazuzu: The clouds is just lit with several spotlights with different softness/shadow intensity/ and color.
I think Serg made a post in the "pyroplastic noise demystified" thread that show a good scatter fake with 3 spotlights.
I used shadowmap for the plane shots since there where noe reason to trace it , but in the space sequence when i had to move the cam over huge distances i raytraced all clouds.
Should mention that the breakdown isnt based on the final grade, so colors may look a bit strange someplaces. The clouds looked much better after grade :)
