Toms "Learning Houdini" Gallery
Thomas Helzle
ojjj i see someone (inspirationeee) niceeeeeeeeeee
can you share some hip..  mmm  i see that you got insp from my sharing ..can you share your on audio Wave please <3
or i asking for to much  ...
Edited by srletak
Hahahah - funny. Just checked your thread and it seems we indeed had some similar ideas. :-)
I don't share files of released artwork, but if you need help implementing the audio import code I linked to in my post, I'm happy to help. Although be warned: as I wrote it was my first ever python code, only works for 24Bit/48KHz wave files and it turned out quite slow being singlethreaded. I never liked chops so thought I should at least give it a try - and at least it was simpler than the C++ API...  ;-)
Still looking for a good OpenCL FFT, all I found on the web was embedded in C++ and I'm not good enough a programmer to extract it...
I'm travelling right now but I can get back to you next week if you want.
Edit: Now posted here:
Cheers,
Tom
Edited by Thomas Helzle
  • 2 weeks later...
  • 2 months later...
Organics: "Lace"
The queen decided that for her 3389th birthday, she would wear nothing but the most intricate laces.
Thousands of trained silk worms were worked to exhaustion.
But the result was worth it...
This one needed to be rendered as Redshift hair instead of cylindrical strands that I use normally, since my 64 GB RAM did not suffice for the conversion...
Cheers,
Tom
  • Like 2
  • 1 month later...
"Be a tree"
Let the breeze blow gently through your leaves.
Let the sun nourish and warm you.
Give birds and squirrels a home.
Drink deep from the ground.
And when the storm comes, give it your all.
Blender with "The Grove" plugin for the tree, Houdini making it into strands and create pseudo-leaves, Redshift for rendering, Luminar to make it cheesy ;-)
And a "dry" version:
Cheers,
Tom
  • 2 weeks later...
  • 1 month later...
