Simple UV problem
polvy
Hi!
I don't know how to solve a simple UV problem, I created a basic file where i can recreate my case. I just want to get UV's sticked to the geometry, even if there is a rotation or gets partialy deleted. I tried using Vertex Sop for MAP matching, but no results. Can you help me?
Thanks!
UV_Problem.hiplc
Ok i found the solution, i was trying to unwrap after the cache simulation. I resimulate again and applied the unwrap before and no problem this time. So I asume that it has to be done always before saving cache files..
Thanks!
