assuming you have pieces neatly separated, kind of what a voronoi fracture would output you, you can just pack via an assembleSOP (check "create Name attribute" and "create packed geometry").
This will give you one packed primitive per piece and thus one point. You can manipulate them as you need via the intrisic attribute "transform"
A point wrangler running this code should get you on the tracks.
float _seedpiece = rand(@ptnum);            // multiplier per piece
float _seed = fit01(_seedpiece, 0.5, 1);    // unique rotation speed multiplier
float _startframe = ch("startframe");
float _fadeout = ch("fade_out") * _seedpiece;
matrix3 _m = ident();   // initial transformation matrix
float _angle = (clamp((@Frame - _startframe), 0, 1000) * _seed) * ch("speed");
vector _axis = set(rand(@ptnum + 1), rand(@ptnum + 5), rand(@ptnum + 9));   // random rotation acix
_fadeout = 1 - fit(clamp(@Frame - _startframe, 0, _fadeout), 0, _fadeout, 0, 1);
vector _scl = set(_fadeout);
rotate(_m, _angle, _axis);
scale(_m, _scl);
setprimintrinsic(0, "transform", @ptnum, _m);
Edited by iamyog
typo
