Is AMD potentially risky? (Threadripper)
kemijo
Hi!
I'm about to start building a 1950X based PC, and just wanted to quickly check from first hand Threadripper users working with Houdini if you've experienced any reliability issue or any other problem that could prevent you from recommending these CPUs for Houdini users.
Also, I have serious doubts regarding motherboards, all that gaming kids marketing just kills me... any recommendations is welcome...
Edited by asmartkid
30 minutes ago, Pancho said:
So far no problems. ASRock X399 Taichi with Air cooling. Temps under load around 56-60°C. 128GB.
23 minutes ago, tricecold said:
Same rig, pretty stable on Linux and Windows. Very happy
Thank you guys, I heard of some issues when Threadripper launched but good to know it was fixed shortly.
What I would like to know is what kind of temperatures other X1950 users achieve with what kind of cooling. Currently there are 4 case fans (200mm) with quite a lot of power, but also with an incredible loud sound. There are other ventilators with about half of the air volume per hour, but much more quiet. Wonder how much the temps will rise, if I exchange them.
  • 1 month later...
I'm currently building my 1950x based workstation with a Noctua 14S TR4-SP3 and a Carbide 600Q sound-dampened case with three 140mm stock fans. If you can wait for some days I'll pass some information if you're still interested...
First stress test to my just built workstation (with the above configuration), using Mantra and some other intensive applications : cpu temperature around 60-62C after several hours of 100% use, with case fans at high speed (but barely audible). Extremely positive first impressions, really happy with this configuration.
  • 1 month later...
