MrHoo Posted February 15, 2018 Share Posted February 15, 2018 (edited) Hi folks, I am following Steven Knipping's tutorial Rigids II and have some behaviour here which I do not understand and can't solve somehow... You'll see the issue in the attached gif (some of the cluster in the upper part of the hole) I have basically the same settings as in his videos, but it seems that somehow the constraints are going to stick together after they are broken. At least they should break because of the metaball force (which I am using) and the corresponding huge hole inside the building and everything should collapse and not stay like in the gif. First I thought the "Overwrite with SOP" parameter on the constraint network would be the issue (which I then changed to $SF==1), but it didn't help. I am using H16.5.323. Thanks for any ideas and suggestions Cheers Dominik Edited February 19, 2018 by MrHoo Quote Link to comment Share on other sites More sharing options...
MrHoo Posted February 17, 2018 Author Share Posted February 17, 2018 Maybe I should really attach a scene file - so here it is.. houseDestruct_v004.zip Quote Link to comment Share on other sites More sharing options...
Noobini Posted February 17, 2018 Share Posted February 17, 2018 I simply open, run up to about frame 50, you can see clearly a big chunk falling down instead of regluing itself back up like your gif Apprentice 16.5.378 Quote Link to comment Share on other sites More sharing options...
MrHoo Posted February 18, 2018 Author Share Posted February 18, 2018 (edited) Hi Noobini, you are right, I tested with 378 and do not have the resticking behaviour. But what is bothering me is, that I should get at least a very similar destruction like in the video at 0:15 (in my case with just one explosion), but the structure has to collapse. I can't of course post a screencap of the orginal tutorial... So any ideas regarding that issue? Thx Dominik Edited February 18, 2018 by MrHoo Quote Link to comment Share on other sites More sharing options...
DonRomano Posted October 16, 2018 Share Posted October 16, 2018 Hey, I have the same problem, did you find any solution ? Quote Link to comment Share on other sites More sharing options...
vicvvsh Posted October 17, 2018 Share Posted October 17, 2018 Hi Dominik, You can change position of a metaball. You can also increase it weight, or increase force and at the same time set density parameter in rbdpackedobject to 2400 (density of concrete) for decreasing speed of pieces. If your setup is different then in the tutorial it is worth to adjust some parameters for your needs. Quote Link to comment Share on other sites More sharing options...
