Houdini Alembic export to Maya, with instancing
toadstorm
I'm trying to export an ABC from Houdini with instancing enabled. I have a bunch of regular packed primitives with a Cd attribute on the points, and they're being written out to disk just fine. Instancing on the Alembic ROP makes these files very manageable.
However, when loading these in to Maya via the VRayMesh proxy loader, the Cd attribute isn't detected as a color set. Additionally, in Houdini, if I try to read this Alembic back in, the Cd attribute is gone, even after unpacking.
I'm using 16.5.439. Anyone have any ideas?
if I colour points...didn't work...changed to vertex....worked..(no, didn't test with vray..just a straight abc import)
worked in Maya and also reading back in Houdini, I'm using Apprentice so cannot do an abc sequence....only 1 frame.
(for reading back into Houdini, colour point was enough to work....but not with Maya, Maya needs it on vertex)
Edited by Noobini
Thanks for taking a look, but what I meant was getting per-instance attributes to export. In order for instancing to work for the Alembic export, I need to export packed geometry, but if I want those instances to have arbitrary attributes of their own (like @Cd), Houdini doesn't seem to be able to export them. I'm suspecting after looking at more of the Alembic specification that this sort of thing just isn't supported, though I wonder if someone's found a workaround?
yes I 'pack and instance' on my copy...whether that satisfies your condition...I'm not sure
(also since using Apprentice, I can only rclick>save geo...1 frame...so it could be entirely different to an abc ROP ?)
Edited by Noobini
Unfortunately not, since the attributes we're talking about would be baked into each instance before packing, which means each instance of a particular color would be unique. I was hoping for a similar workflow to adding a @Cd attribute to packed primitives post-packing and using that to vary copies. The end product is supposed to have hundreds of thousands of instances with many different colors applied, so assigning colors to copies pre-copy operation is not going to be efficient enough.
I was playing around with trying to recreate the situation you have described. But I find that Houdini can't write an Alembic file that references instances. When I export the .abc file it is only 2K and unreadble...
Is there some other setup required to export and instance of a packed primitive animation?
ap_toads_instance_packed_problem.hiplc
correct me if i'm wrong but i think alembic doesn't support anything else than polygonal geometry with standard attributes (like N, uv...). no instancing, no packed geo, no custom attributes, no anything. And I guess it doesn't really matter as other software packages wouldn't know how to read it anyways.
Yeah, I guess I was misreading the flag "use instancing where possible." It's just data de-duplication in Alembic. So it looks like there's no easy solution to this problem.
If you change the deployment from Instance to CopyToPoints the Alembic export node will write them out as individual meshes with the Cd attribute embedded. I don't have Maya but I can see that Blender can detect my @Cd colors when importing an Alembic cache. You do end up with a larger file this way, however.
@Atom, The confusingly-named "use instancing" option on the Alembic ROP can leverage packed primitives to keep the file size down. If I weren't using packed prims, getting color sets and other vertex data would be no big deal, but I'm dealing with a situation that involves hundreds of thousands, possibly millions of copies, so the resulting Alembic would end up way too heavy.
@StepbyStepVFX I'd definitely do this if Maya's Alembic build supported particles, but as is typical with Maya they're years behind in their implementation. Unless they've updated something very recently, it's impossible to get particles into Maya via Alembic.
Forget about importing the particles as Alembic : seems you can use the Houdini Engine, importing an HDA that contains a file SOP pointing toward a bgeo file that contains the particles.
From there, you can instance objects on your particles directly into Maya (it seems that importing that HDA through Houdini Engine creates a classic Nucleus particle system, from what I see on the video below) :
Edited by StepbyStepVFX
  • 10 months later...
Has anyone figured out any workarounds to get instanced packed pieces out to Alembic and into Maya?  It seems to have been a consistent problem for quite a while, and I've still not seen any decent ways of handling it.
In many cases these caches are being passed off to lighters that don't want to or can't mess with Houdini Engine, and I assume the cloud rendering services that lighters are likely to use won't support Engine either.  I suppose one could potentially get the points into Maya via Engine, then do an nCache and add instances to that, but that's a painfully awful workflow.  And that's without factoring in the headache of converting Houdini's per point matrix or orient to an Euler rotation that (I think) Maya expects, and comparing back and forth to make sure your instancing in Maya matches your instancing in Houdini.
I seem to remember there being a way to export point particles to Alembic if you add a particle system primitive in Houdini before exporting.  You can do this with an Add SOP with 'Add Particle System' turned on.  In the quick test I ran, the resulting alembic creates a Maya particle system on import, and seems to recognize all my custom attributes from Houdini, but doesn't seem to actually contain any points.  Maybe there's a simple step I'm missing to get that to work?
Also, if you really do need to build Euler rotations from a quaternion, you can try this painful bit of VEX code from my library of snippets.  In this case I was getting the rotation based on a normal vector direction, but you could directly use @orient instead of the dihedral thing.
vector4 q = dihedral( {0,1,0}, @N );
v@rot = {0,0,0} ;
@rot.x = degrees( atan2(2*(q.w*q.x+q.y*q.z), (1-2*(q.x*q.x+q.y*q.y))) );
@rot.y = degrees( asin(2*(q.w*q.y-q.z*q.y)) );
@rot.z = degrees( atan2(2*(q.w*q.z+q.x*q.y), (1-2*(q.y*q.y+q.z*q.z))) );
From the Alembic 1.7.1 source code:
Quote
printWarning("Reading animated particle data not supported.");
I'm not sure if Autodesk itself uses the same original sources, but it seems so. So I fear there you will have no luck reading an animated sequence. We solved the problem (with Maya 2015) by building our own abc reader plugin which can be connected to a particle instancer what work quite well.
  • 1 year later...
Heya
digging up this old  thread to see if theres been any developments in this issue. Or if anyone found a solution?
I also can't use the houdini engine workaround cause of our studio pipeline.  :(
Fortunately i can get alembic points inside maya trough Vray proxy but this way i'm limited to having only spheres. If theres another way to get the points recognized inside maya then maybe its possible to use them to instance geometry into them.
