Smoking In The Building
Val
  Val said:
I use this texture (attachment)
and I use point SOP with 'AddAlpha' for particle AGE..
to make smoke disappear.
thanks for coments :D
26731[/snapback]
Do you use particles for your smoke - or is it a geometry (like the smoke in Houdini Help - one of the tutorials)?
26946[/snapback]
Hey yvajaemii :)
yes I use particles for motion (like in help tutorial),
I do not have file this moment (I am in LA for one week)..
but I did quick version:
I use "AddColor" just to see in viewPort ...
(click on pic to see BIGER pic)
Val
  • 2 months later...
here is direct link:
http://www.sidefx.com/docs/content/base/tu...cts_1022161.xml
you can use particles life to make smoke disolve
(not in tutorial).
do not use variation for particles life,
or conected poligons (add_sop) will be constantly
changing and will looks wierd :D
you can do same smoke without SKIN-sop.. just render splines with shader
Val
