Select Pts with One Connection
One thing to keep in mind is that code will return both the start and end points, as requested in the first post. But if you just want the end point or start point you may need to filter for that by looping over the primitives and detecting point #0 or point # @numpt.
// @ptnum is zero based.
if (@ptnum==(@numpt-1)){i@group_ends=1;}
Edited by Atom
no loops necessary and you should try to avoid them if you can
also first point of the primitive doesn't guarantee that it's at the start or at the end or even that the primitive has any start or end if it's closed, so you are better off using points belonging to first or last vertex and either checking if the prim is closed or using the neighbourcount() test
so to detect all you can combine first test with test whether point belongs to the first or the last vertex of the primitive
int pts[] = primpoints(0, @primnum);
int isend = neighbourcount(0, @ptnum) == 1;
int isfirst = @ptnum == pts[0];
int islast = @ptnum == pts[-1];
i@group_ends = isend;
i@group_start = isend && isfirst;
i@group_end = isend && islast;
OR mentioned open/closed poly test
int isopen = !primintrinsic(0, "closed", @primnum);
i@group_ends = isopen && (isfirst || islast);
i@group_start = isopen && isfirst;
i@group_end = isopen && islast;
  • Like 3
  • Thanks 1
