Why is it not possible to delete P with attribute delete?
bobbybob
I ran in to this problem, because I have a sphere, and I need a deformed version of it, but only as a rest attribute. I know how to do this in other ways, but I thought, that to just make the deformation, create the rest, delete the P attribute and then merge it with the original sphere would be nice. But when trying to delete the P attribute with a Attribute Delete, nothing happens?
Is this because P is a special attribute or something? Would be interesting to know.
Plugin both versions in an attribwrangle. Then you can take over the rest attribute from the second input with:
v@P = @opinput1_rest;
Morphing between both positions would be:
v@P = lerp(@P, @opinput1_rest, chf('morph') );
Point positions cannot be deleted, but you can set them all to zero:
v@P = vector(0);
