Whitewater houdini 17
polterizer
Hey!
Once im testing the new ww, wanted to ask here some points of the new h17 ww :
- Seems very slow sim in big flip simulation, 4x more slow than the old ww of 16.5, probally my bad but i leave most default just for test lol... and i dont use the opencl, also disable stiffness "constraint stiffness as 0". any know what is doing slow? sometimes crash the pc more than 200% ram used..
- One thing interesting for me is i am seeking where i can disable the spray and bubbles? where i can control the spray? :D.
thanks
cheers
Carlos
Edited by polterizer
 hi Carlos,  I'm not sure what is slowing your scene down so much.  I've found the new whitewater solver to be much faster/better than the old one.  I don't think you can set constraint stiffness to 0 and still get usable results (not sure though).  Unfortunately there isn't a tut on the new whitewater solver,  but this tutorial is related:  (the pop fluid node is inside the ww solver).
 -G
hey,
yeah, must see a tut, i was testing tweaking stuffs, i dissable the clumping density control and doest fast sim, looks more faster than old one, the problem seems the density control, that makes me 200% ram out, also i increased the voxels for a low density but doesnt make sense. lets see the comming tutorials :D
thanks for the tips!
  • 1 month later...
On 10/22/2018 at 5:31 PM, polterizer said:
hey,
 -G
Polterizer seems to stand correct regarding the whitewater solver issues when doing BIG/HEAVY sims. My H17 keeps crashing every time due to extreme RAM values. Did you ever figure this issue out? The only thing I could successfully output was the whitewater source cache.
Edited by Solo
Cache the emitter and try partition it into smaller sims. Its advecting thru a velocity field and I dont think anyone will notice if its not perfectly density constrained.
Edited by mawi
Ahhh yes. I forgot about that idea despite doing this in the past! Thank you.
Here is my simple code for grouping H17 particles into pre H17 whitewater groups.
i@group_foam = 0;
i@group_bubbles = 0;
i@group_spray = 0;
if (@spray>0.0) {
    i@group_spray = 1;
} else {
    if (@foam>@bubble) {
        i@group_foam = 1;
    } else {
        i@group_bubbles = 1;
  • Like 2
  • 3 weeks later...
I have the same problem with memory consumption of the ww solver in H17 (windows).
Switching off the density control reduces memory consumption to about 25%.
In my actual sim I can only get to around 7 million particles. But I would need something like 50+ million to get a decent look.
So is this a bug or does the density feature just need this massiv amount of RAM?
Cheers
Rico
  • 2 weeks later...
  • 6 months later...
  • 1 month later...
  • 1 month later...
