kiryha Posted December 18, 2018 Share Posted December 18, 2018 How to make the bottom row (or 5 cubes in right bottom corner, or any other user-defined portion of cubes) of RBD packed objects static (not falling but calculated in solver)? statueBreak_001.hipnc Quote Link to comment Share on other sites More sharing options...
Sepu Posted December 18, 2018 Share Posted December 18, 2018 (edited) There are many ways to do this, one easy way is just to group the points that you do not want to affect, then in a wrangle add the group in the tab group !mygroup and vexpression add this i@active = 1; Edited December 18, 2018 by Sepu 1 Quote Link to comment Share on other sites More sharing options...
kiryha Posted December 19, 2018 Author Share Posted December 19, 2018 (edited) Works, but not as expected. If I understand correctly reversing group with "!" does not work. Try to invert active = 0, does not work as well... statueBreak_002.hipnc UPD. "* ^mygroup" is working. Edited December 19, 2018 by kiryha Quote Link to comment Share on other sites More sharing options...
Noobini Posted December 19, 2018 Share Posted December 19, 2018 huh ? what am i missing ? seems to work as expected to me either group or !group....both work as expected. Quote Link to comment Share on other sites More sharing options...
kiryha Posted December 19, 2018 Author Share Posted December 19, 2018 (edited) Now for me as well. Wired... Edited December 19, 2018 by kiryha Quote Link to comment Share on other sites More sharing options...
kiryha Posted December 19, 2018 Author Share Posted December 19, 2018 (edited) Should this setup work with constraints? I setup constrains network and it working only if I turn off the wrangle with @active attribute. Excluding static pieces from constrain network also works... so never mind. Edited December 19, 2018 by kiryha Quote Link to comment Share on other sites More sharing options...
kiryha Posted December 19, 2018 Author Share Posted December 19, 2018 Now I can't replicate the same task with constraints. I need the same static behavior of the bottom part for some time and then RBD it as well. I can not link bottom part to the BASE no matter how high I raise the strength. statueBreak_003.zip Quote Link to comment Share on other sites More sharing options...
Sepu Posted December 19, 2018 Share Posted December 19, 2018 (edited) inside the DOPs you can add a sopsolver and break the constraints at the frame or use any other condition that you wish. There is a group call broken which Houdini understands so if @group_broken = 1; then the constraints will break. Edited December 19, 2018 by Sepu 1 Quote Link to comment Share on other sites More sharing options...
kiryha Posted December 19, 2018 Author Share Posted December 19, 2018 I realize how I can break the constraint, but I can't make them unbreakable first! Quote Link to comment Share on other sites More sharing options...
Sepu Posted December 19, 2018 Share Posted December 19, 2018 Is this what you want? right now the bottom part is breaking at Frame 50. statueBreak_004.rar 1 Quote Link to comment Share on other sites More sharing options...
kiryha Posted December 19, 2018 Author Share Posted December 19, 2018 (edited) Not exactly... The statue is located on the BASE (ground plane located lower) and I need to constrain legs to the base and demolish them after the top part fall apart (yes, like in frame 50 or later). So I don't know how to link (constrain) constrained geometry to something static. Now legs are not static, they just fall down to the raised floor. Edited December 19, 2018 by kiryha Quote Link to comment Share on other sites More sharing options...
Sepu Posted December 19, 2018 Share Posted December 19, 2018 I didn't have the base btw that is why I raise the ground plane, but anyway, you can have different kind of constraints, there is glue, hard, etc and they all can have different properties so you can affect them differently to give you what you want. You can set up all that in SOPs (different properties, strength, ...) and then manipulate that data in the sop solver, where you can have constraints that can break if a condition is met, animate geometry to break them, use an attribute transfer, use point clouds, you could also change constraints at different frames/conditions, etc. 1 Quote Link to comment Share on other sites More sharing options...
Noobini Posted December 19, 2018 Share Posted December 19, 2018 (edited) well to me....you need to do a bit of housekeeping...ie. a null with caps.....blah blah...you know the drill... Right now, in your DOP, the static base SOP path is /obj/STATUE_BREAK/BASE which is wrong.....it is non existent....you've stashed it...and yes the stash works....so if you change the above to /obj/STATUE_BREAK/pack1 you'll see the base doing its part in the sim...no, I haven't verified if everything is working as you intended...only you would know that. But anyway, had you created a null after the pack1 and called it OUT_BASE.....then when you come to pick it....you would've picked the right one. EDIT: I guess for you, it may look like it's working...coz YOU have the file on your drive...but for other ppl, they don't....so if you refer to a point above the stash...ppl would not see the base. Edited December 20, 2018 by Noobini 1 Quote Link to comment Share on other sites More sharing options...
kiryha Posted December 20, 2018 Author Share Posted December 20, 2018 (edited) I understand this on a high level, Herman, but when it comes to the particular case, there are always some issues raised! > well to me....you need to do a bit of housekeeping...ie. a null with caps.....blah blah...you know the drill... What do you mean? To clean up and organize the scene? > /obj/STATUE_BREAK/BASE > which is is wrong.....it is non existent.| My bad did not fix it in the scene I shared, in the original scene the BASE is working fine. Ok, I was able to sort out how to setup legs linked to a base with constraints. Now I need to modify "strength" and the obvious way to animate it in DOP does not work (see attached scene). How can I do it in another way? I plan to setup changing constrains strength with some control objects in space, but for beginning, the most simple way will work. animConstr_001.hipnc Edited December 20, 2018 by kiryha Quote Link to comment Share on other sites More sharing options...
vicvvsh Posted December 20, 2018 Share Posted December 20, 2018 (edited) "Set Always" for animated parameter "strength" in glue constraint relationship node should help you. Edited December 20, 2018 by vicvvsh 1 Quote Link to comment Share on other sites More sharing options...
