Show Texture in Viewport
Show textures in the viewport only works for me if I plug the texturepath directly into the shaders parameter. If I use a texture sop or create a string parm to the texture it will not be displayed in the viewport. A workaround is that I unlock the shader and create a parameter inside with the path to the texture and with "texture" tag. But outside of the shader on mat level it will not work for me. Any tipps how to fix that? Thank you.
That is what I do as well, place it last in the network. But be careful where you place your render flag. When you use a uvquickshade it overwrites the @shop_materialpath which can clobber your render material. I set the Display flag on the uvquickshade, then CTRL-CLICK on on the node above to set the render flag.
Edited by Atom
Thanks for your fast replies. Yes I am aware of that technique but I tried to avoid that.
Since its possible to show the textures directly from the material if I plug it into the shader texture parameter directly, I thought it should also be possible to show the textures of the texture node somehow with the same technique.
Edited by jon3de
misspelling
