Houdini Pyro OpenCL Error
Mozzarino
19 minutes ago, Atom said:
Maybe the error is giving you a hint. Are your supplied fields of the same resolution?
I tried already using the field match to make them have the same resolution and it didn't work...
This problem only exists when I am using OpenCl... :s
  • 2 years later...
I'm running into this same error but only when I try to use pressure as a control field for disturbance/turbulence in the pyro SOP solver.
Disabling openCL solves the problem, but my sim is quite a bit slower. Has anyone run into this error recently?
Edit: I dove into the pyro SOP solver and disabled openCL only on the gas disturb and gas turbulence nodes, leaving the rest enabled and it works fine now since openCL is enabled for everything else.
Edited by smbell
