How to apply Turbulence to Pressure field?
bifrost
Hey guys, can anyone here help me with how to mask my turbulence to my pressure field that pyro creates by default?
I tried looking around and a lot of posts have been made talking about that it's a really good way to get rid of mushroom looks and add details at the start of the sim. But I cant find an example file for it. Any help on the subject would be awesome.
6 minutes ago, RoaringDog said:
I think you can use pressure as a control field in Turbulence microsolver.
Thanks for the reply Madi. Is there a way to visualise that pressure field?
Edit: just tried pressure as a control field. Doesn't work. There is no difference in the sim with or without it. :(
Edited by bifrost
9 hours ago, Jesper Rahlff said:
hm it should work. Did you set the control influence to 1 and then remap the values?
I will give this a try. May be I need to control range on that. Also is there a way to visualise your pressure field?
