eyfox 0 Posted March 5 (edited) Hallo everyone, i am new here. I have searched for a solution to this problem, but cant find one. I want to transfer a point-attribute from a polysurface with uvs into COPS. Just like it works with heightfields and the "Sop Import"-node. I read that the qLib "uvPointCloud ql" would be the solution for this, but the node does not work for me. There is a warning that the "ray_ql1"-node inside is using an incomplete asset definition? UPDATE: Solved the issue with the "ray_ql1" node by importing the asset manually from the qLib-folder, but still could not get it to work unfortunately. Also found out that i could convert the polySurface into a volume and then get the colors from there into cops with "Sop Import"-node i guess, but not sure how to go about making the volume with the inherited color-attribute? thanks, Marcus Edited March 5 by eyfox Share this post Link to post Share on other sites
symek 343 Posted March 5 Not sure if I understand correctly, but if you want to bake in COPs point attribute in uv space, then VEX works as usual: vector uv = set(X, Y, 0); vector clr = uvsample("op:/obj/geo/geometry", "Cd", "uv", uv); R = clr.x; G = clr.y; B = clr.z; Copy this (replacing path and attribute name) into Snippet VOP inside vopcop2filter and you should have the attribute baked into texture. 4 1 Share this post Link to post Share on other sites
hughspeers 0 Posted June 4 Hi Symek I'm trying out your snippet suggestion but failing to get it to work. I think I'm missing some basic piece of the knowledge puzzle. I've made a simple example but I'm not able to see my colour attribute spread out in the cops viewport as a flattened uv image. Any light shed would be most appreciated thanks John Attribute_to_cops_by_UV.hip Share this post Link to post Share on other sites
symek 343 Posted June 4 I literally haven't done anything except changing constant color to bounding box to emphasize the effect and it does work here (17.0.416 - OSX). COPS have some issues with refreshing. They might not notice your changes and keep displaying old image. Maybe this is your problem? 1 Share this post Link to post Share on other sites
hughspeers 0 Posted June 5 Hi Symek thanks for checking the scene file. You are absolutely right it must have been cops cache problem. When I opened it this morning its working. I'm often caught out by a cache problem in houdini and chasing my tail for an hour before I open and close a scene ! I see the qlib tools mentioned above by eyfox have a flush cache in the shelf tools, I'll give that a go. Thanks again Symek John Share this post Link to post Share on other sites
