joahky7 Posted July 28, 2019 Share Posted July 28, 2019 Hi I am in the midst of crossing over from Realflow to Houdini, along other 3D apps. Likely to be a very basic question - am trying to show sim details in Render window. Eg. running a flat tank and trying to display sim particles information etc. Anyone kind enough to let me know if there is a hot key or? Thanks Quote Link to comment Share on other sites More sharing options...
catchyid Posted July 31, 2019 Share Posted July 31, 2019 i always have the same exact requirement, but so far I have not found an easy way to do it! anyways, here are some pointers: -you can use visualize node and find the attribute you want to display --> obviously, you need to find this number, i.e. num particles and use visualize node to display it -you can use font node to display also information --> you should align font to camera so you can see the text in the camera view! if that is easy for you then do it, but you still need to find the number you want to display -you can ignore all that, and just look at the geometry spread sheet, sort by point number and see how many particles you (you can say I will look at first frame, mid frame and last frame to give you a rough average) I would suggest the last idea is the easiest and fastest one 1 Quote Link to comment Share on other sites More sharing options...
bunker Posted July 31, 2019 Share Posted July 31, 2019 Can you give some details about what "sim particles information" you want to display? not sure how many people use Realflow here. Quote Link to comment Share on other sites More sharing options...
cudarsjanis Posted July 31, 2019 Share Posted July 31, 2019 That`s one way to do it. Font node and point expression http://www.sidefx.com/docs/houdini/expressions/point particleCount.hip Quote Link to comment Share on other sites More sharing options...
joahky7 Posted August 1, 2019 Author Share Posted August 1, 2019 On 31/07/2019 at 1:45 AM, bunker said: Can you give some details about what "sim particles information" you want to display? not sure how many people use Realflow here. Primarily particles counts and a subset of parameter settings I used for the FLIP sim: Particles count: xxx Particles Separation : xx etc So that I can keep a record of the simulation parameters I used. Quote Link to comment Share on other sites More sharing options...
joahky7 Posted August 1, 2019 Author Share Posted August 1, 2019 On 31/07/2019 at 3:23 PM, cudarsjanis said: That`s one way to do it. Font node and point expression http://www.sidefx.com/docs/houdini/expressions/point particleCount.hip Thanks, guess this might possibly be one efficient way, though with added computation time per simulation. Would be nice for Houdini to come out a template, similar to Realflow to view parameters but with low overhead count. Greatly appreciated! Quote Link to comment Share on other sites More sharing options...
joahky7 Posted August 1, 2019 Author Share Posted August 1, 2019 On 31/07/2019 at 1:10 AM, catchyid said: i always have the same exact requirement, but so far I have not found an easy way to do it! anyways, here are some pointers: -you can use visualize node and find the attribute you want to display --> obviously, you need to find this number, i.e. num particles and use visualize node to display it -you can use font node to display also information --> you should align font to camera so you can see the text in the camera view! if that is easy for you then do it, but you still need to find the number you want to display -you can ignore all that, and just look at the geometry spread sheet, sort by point number and see how many particles you (you can say I will look at first frame, mid frame and last frame to give you a rough average) I would suggest the last idea is the easiest and fastest one Thanks, have been using the spreadsheet - nice to have but not easily recordable for simulations that I do to optimise various parameters. Greatly appreciated! Quote Link to comment Share on other sites More sharing options...
Lucy Coleclough Posted August 1, 2019 Share Posted August 1, 2019 You can easily show geometry information in the viewport but I don't know how to show parameter values there outside writing a plugin. If you hit D in the viewport and go to guides/geometry information, it'll show you point and prim counts Quote Link to comment Share on other sites More sharing options...
Pancho Posted April 21, 2021 Share Posted April 21, 2021 Write a python script to collect all the parms of the selected nodes you like to display. Display the formated parameters in the console and copy them into the font node. p.label() is the name you want to display, p.name() the name of the parameter which you need to connect to the node path, like "/obj/geo/" + "xrows". Quote Link to comment Share on other sites More sharing options...
ANSHUL_VASHIST Posted May 21, 2021 Share Posted May 21, 2021 Go to display Option by hitting "D" and then in the Guides Tab you will found "Geometry Information", it's always off so select always on. That's it you are done. Quote Link to comment Share on other sites More sharing options...
anicg Posted May 22, 2021 Share Posted May 22, 2021 I came across this, I hope it helps: Quote Link to comment Share on other sites More sharing options...
nguyenvuquocan Posted May 24, 2021 Share Posted May 24, 2021 File Sop > Load Tap > Info . " Creates one point if the file loads successfully and attach attributes for each named component of the meta-data. " Quote Link to comment Share on other sites More sharing options...
