Optimize Collision calculation - Houdini Quicktip!
Jesper Rahlff
On 2019-10-03 at 11:21 AM, Skybar said:
If you are only transforming the collision geo, you can do that directly on the geo node (obj level). It will then use those transforms if you've chosen it in the "OBJ Path" parameter on the Static Object DOP.
Yeah but I generally do not like to place transform information on the obj level. Thanks for pointing that out though. might be useful for other people.
