CinnamonMetal Posted February 2, 2020 Share Posted February 2, 2020 How can I get vellum to create protruded shapes as seen in the image below ? Quote Link to comment Share on other sites More sharing options...
Yader Posted February 3, 2020 Share Posted February 3, 2020 One way to achieve this with Vellum could be to animate rest blend geometry from flat to protruded and reference that into the Vellum Rest Blend DOP. Quote Link to comment Share on other sites More sharing options...
Yader Posted February 3, 2020 Share Posted February 3, 2020 Here's an example file illustrating the above: Protruded_Vellum_Shape_02.hiplc 5 Quote Link to comment Share on other sites More sharing options...
Atom Posted February 3, 2020 Share Posted February 3, 2020 That is a nice example file. I guess you can use it for logos, too. Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted February 3, 2020 Author Share Posted February 3, 2020 @Yader Why am I getting all these errors; is it because I'm using H 17.5 ? Load warnings for C:/1/Protruded_Vellum_Shape_02.hiplc Quote Warning: /obj/geo1/attribwrangle3: Skipping unrecognized parameter "vex_precision". /obj/geo1/attribwrangle4: Skipping unrecognized parameter "vex_precision". /obj/geo1/attribvop1: Skipping unrecognized parameter "vex_precision". /obj/geo1/attribvop1/bind1: Skipping unrecognized parameter "surfacedef". Skipping unrecognized parameter "displacementdef". Skipping unrecognized parameter "atmospheredef". /obj/geo1/vellumcloth1: Skipping unrecognized parameter "stretchtype". Skipping unrecognized parameter "preservevol". Skipping unrecognized parameter "linear". Skipping unrecognized parameter "sepparm". Parameter value calcvarying in domass is invalid. Defaulting to 0. Skipping unrecognized parameter "density". Skipping unrecognized parameter "scaledensitymode". Skipping unrecognized parameter "scaledensityattrib". Parameter value calcvarying in dothickness is invalid. Defaulting to 0. Skipping unrecognized parameter "thicknessscale". Skipping unrecognized parameter "scalethicknessmode". Skipping unrecognized parameter "scalethicknessattrib". Skipping unrecognized parameter "vizthickness". Skipping unrecognized parameter "sepparm2". Skipping unrecognized parameter "dosliding". Skipping unrecognized parameter "slidingrate". Skipping unrecognized parameter "slidingscalemode". Skipping unrecognized parameter "slidingattrib". Skipping unrecognized parameter "glue_minradius". Skipping unrecognized parameter "glue_searchpref". Skipping unrecognized parameter "stretchstiffnessexp". Skipping unrecognized parameter "compressstiffnessexp". Skipping unrecognized parameter "compressstiffnessscalemode". Skipping unrecognized parameter "compressstiffnessattrib". Skipping unrecognized parameter "compressstiffnessscale". Skipping unrecognized parameter "dotangent". Skipping unrecognized parameter "tangentstiffness". Skipping unrecognized parameter "tangentstiffnessexp". Skipping unrecognized parameter "dostretchvelblend". Skipping unrecognized parameter "stretchvelblend". Skipping unrecognized parameter "stretchvelblendscalemode". Skipping unrecognized parameter "stretchvelblendattrib". Skipping unrecognized parameter "bendstiffnessexp". /obj/geo1/vellumsolver1: Skipping unrecognized parameter "veldamping". Skipping unrecognized parameter "folder7". Skipping unrecognized parameter "domultipass". Skipping unrecognized parameter "maxmultipass". Skipping unrecognized parameter "disablestretchratio". Skipping unrecognized parameter "folder5". Skipping unrecognized parameter "normalizestress". Skipping unrecognized parameter "slidingmethod". Skipping unrecognized parameter "folder6". /obj/geo1/grouppromote1: Skipping unrecognized parameter "onlyboundary1". Skipping unrecognized parameter "includeunshared1". Skipping unrecognized parameter "useconnectivityattrib1". Skipping unrecognized parameter "connectivityattrib1". Skipping unrecognized parameter "primsbyattribbndpts1". Skipping unrecognized parameter "removedegen1". /obj/geo1/grouppromote2: Skipping unrecognized parameter "onlyboundary1". Skipping unrecognized parameter "includeunshared1". Skipping unrecognized parameter "useconnectivityattrib1". Skipping unrecognized parameter "connectivityattrib1". Skipping unrecognized parameter "primsbyattribbndpts1". Skipping unrecognized parameter "removedegen1". Bad node type found: remesh::2.0 in /obj/geo1. /obj/geo1/remesh1: Skipping unrecognized parameter "group". Skipping unrecognized parameter "hard_edges". Skipping unrecognized parameter "meshing". Skipping unrecognized parameter "iterations". Skipping unrecognized parameter "smoothing". Skipping unrecognized parameter "inputptsonly". Skipping unrecognized parameter "detachfromnongroup". Skipping unrecognized parameter "recomputenormals". Skipping unrecognized parameter "sizinggroup". Skipping unrecognized parameter "sizing". Skipping unrecognized parameter "targetsize". Skipping unrecognized parameter "usemaxsize". Skipping unrecognized parameter "maxsize". Skipping unrecognized parameter "useminsize". Skipping unrecognized parameter "minsize". Skipping unrecognized parameter "density". Skipping unrecognized parameter "gradation". Skipping unrecognized parameter "sizingattribs". Skipping unrecognized parameter "usemeshsizeattrib". Skipping unrecognized parameter "meshsizeattrib". Skipping unrecognized parameter "useminsizeattrib". Skipping unrecognized parameter "minsizeattrib". Skipping unrecognized parameter "usemaxsizeattrib". Skipping unrecognized parameter "maxsizeattrib". Skipping unrecognized parameter "outputattribs". Skipping unrecognized parameter "useoutmeshsizeattrib". Skipping unrecognized parameter "outmeshsizeattrib". The following node types are using incomplete asset definitions: Sop/distancefromgeometry Expand Quote Link to comment Share on other sites More sharing options...
Yader Posted February 3, 2020 Share Posted February 3, 2020 Jupp, that's the reason. I'm using H18 nodes. Let me see if I can make a 17.5 version (The basic workflow should be the same) Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted February 3, 2020 Author Share Posted February 3, 2020 @Yader Thanks, it may answer the question I have Quote Link to comment Share on other sites More sharing options...
Yader Posted February 3, 2020 Share Posted February 3, 2020 Attached is the 17.5 version of the example above Protruded_Vellum_Shape_02_H175.hiplc Quote Link to comment Share on other sites More sharing options...
vinyvince Posted February 3, 2020 Share Posted February 3, 2020 I would like to see it with natural cloth wrinkles. And more interestingly, an interesting idea would be to nice if we could use given UV of an objet to define the cloth sewing (and so drive the wrinkles), as it happen with M with UV patern and pressure Like this, what do you guys think about? Quote Link to comment Share on other sites More sharing options...
Noobini Posted February 3, 2020 Share Posted February 3, 2020 (edited) I used a very basic approach... 9 nodes in total...i mean you can't get more basic than pinning points. Paint + selection...etc...took up majority of nodes...actual Vellum related nodes ? 3 !!! So simple I'd be embarassed to post such a file. Edited February 4, 2020 by Noobini Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted February 4, 2020 Author Share Posted February 4, 2020 @Yader Is @width a new attribute; for vellum ? Quote Link to comment Share on other sites More sharing options...
