Vellum fill into shape ?
CinnamonMetal
@Yader Why am I getting all these errors; is it because I'm using H 17.5 ?
Load warnings for C:/1/Protruded_Vellum_Shape_02.hiplc
Quote
Warning:
/obj/geo1/attribwrangle3:
             Skipping unrecognized parameter "vex_precision".
/obj/geo1/attribwrangle4:
/obj/geo1/attribvop1:
/obj/geo1/attribvop1/bind1:
             Skipping unrecognized parameter "surfacedef".
             Skipping unrecognized parameter "displacementdef".
             Skipping unrecognized parameter "atmospheredef".
/obj/geo1/vellumcloth1:
             Skipping unrecognized parameter "stretchtype".
             Skipping unrecognized parameter "preservevol".
             Skipping unrecognized parameter "linear".
             Skipping unrecognized parameter "sepparm".
             Parameter value calcvarying in domass is invalid. Defaulting to 0.
             Skipping unrecognized parameter "density".
             Skipping unrecognized parameter "scaledensitymode".
             Skipping unrecognized parameter "scaledensityattrib".
             Parameter value calcvarying in dothickness is invalid. Defaulting to 0.
             Skipping unrecognized parameter "thicknessscale".
             Skipping unrecognized parameter "scalethicknessmode".
             Skipping unrecognized parameter "scalethicknessattrib".
             Skipping unrecognized parameter "vizthickness".
             Skipping unrecognized parameter "sepparm2".
             Skipping unrecognized parameter "dosliding".
             Skipping unrecognized parameter "slidingrate".
             Skipping unrecognized parameter "slidingscalemode".
             Skipping unrecognized parameter "slidingattrib".
             Skipping unrecognized parameter "glue_minradius".
             Skipping unrecognized parameter "glue_searchpref".
             Skipping unrecognized parameter "stretchstiffnessexp".
             Skipping unrecognized parameter "compressstiffnessexp".
             Skipping unrecognized parameter "compressstiffnessscalemode".
             Skipping unrecognized parameter "compressstiffnessattrib".
             Skipping unrecognized parameter "compressstiffnessscale".
             Skipping unrecognized parameter "dotangent".
             Skipping unrecognized parameter "tangentstiffness".
             Skipping unrecognized parameter "tangentstiffnessexp".
             Skipping unrecognized parameter "dostretchvelblend".
             Skipping unrecognized parameter "stretchvelblend".
             Skipping unrecognized parameter "stretchvelblendscalemode".
             Skipping unrecognized parameter "stretchvelblendattrib".
             Skipping unrecognized parameter "bendstiffnessexp".
/obj/geo1/vellumsolver1:
             Skipping unrecognized parameter "veldamping".
             Skipping unrecognized parameter "folder7".
             Skipping unrecognized parameter "domultipass".
             Skipping unrecognized parameter "maxmultipass".
             Skipping unrecognized parameter "disablestretchratio".
             Skipping unrecognized parameter "folder5".
             Skipping unrecognized parameter "normalizestress".
             Skipping unrecognized parameter "slidingmethod".
             Skipping unrecognized parameter "folder6".
/obj/geo1/grouppromote1:
             Skipping unrecognized parameter "onlyboundary1".
             Skipping unrecognized parameter "includeunshared1".
             Skipping unrecognized parameter "useconnectivityattrib1".
             Skipping unrecognized parameter "connectivityattrib1".
             Skipping unrecognized parameter "primsbyattribbndpts1".
             Skipping unrecognized parameter "removedegen1".
/obj/geo1/grouppromote2:
             Bad node type found: remesh::2.0 in /obj/geo1.
/obj/geo1/remesh1:
             Skipping unrecognized parameter "group".
             Skipping unrecognized parameter "hard_edges".
             Skipping unrecognized parameter "meshing".
             Skipping unrecognized parameter "iterations".
             Skipping unrecognized parameter "smoothing".
             Skipping unrecognized parameter "inputptsonly".
             Skipping unrecognized parameter "detachfromnongroup".
             Skipping unrecognized parameter "recomputenormals".
             Skipping unrecognized parameter "sizinggroup".
             Skipping unrecognized parameter "sizing".
             Skipping unrecognized parameter "targetsize".
             Skipping unrecognized parameter "usemaxsize".
             Skipping unrecognized parameter "maxsize".
             Skipping unrecognized parameter "useminsize".
             Skipping unrecognized parameter "minsize".
             Skipping unrecognized parameter "gradation".
             Skipping unrecognized parameter "sizingattribs".
             Skipping unrecognized parameter "usemeshsizeattrib".
             Skipping unrecognized parameter "meshsizeattrib".
             Skipping unrecognized parameter "useminsizeattrib".
             Skipping unrecognized parameter "minsizeattrib".
             Skipping unrecognized parameter "usemaxsizeattrib".
             Skipping unrecognized parameter "maxsizeattrib".
             Skipping unrecognized parameter "outputattribs".
             Skipping unrecognized parameter "useoutmeshsizeattrib".
             Skipping unrecognized parameter "outmeshsizeattrib".
             The following node types are using incomplete asset definitions:
    Sop/distancefromgeometry
I would like to see it with natural cloth wrinkles. And more interestingly, an interesting idea would be to nice if we could use given UV of an objet to define the cloth sewing (and so drive the wrinkles), as it happen with M with UV patern and pressure
Like this, what do you guys think about?
I used a very basic approach...
9 nodes in total...i mean you can't get more basic than pinning points. Paint + selection...etc...took up majority of nodes...actual Vellum related nodes ? 3 !!! So simple I'd be embarassed
to post such a file.
Edited by Noobini
