What's the best way to make 3d surface like a wafer biscuit?
Masoud
Hello;
I would like to make a wafer biscuit, so I'm looking for the best way to make 3d surfaces like the image below, in Houdini?
I tried volume VOP + noise + VDB, but creating a suitable noise to mimic surfaces like that, is very hard.
I would appreciate any ideas.
Thanks.
Hi Masoud,
of course any aspect of this needs refinement, but you could first warp the voxel position a little. Then ask whether it has roughly the same distance to two close-by points of a point cloud thus resulting in cell walls (read Voronoi).
You will need a lot of resolution to get thin walls. So it may be better to just do this inside a shader. Also you may want to look through "Anyone can cook" by Pixar: https://graphics.pixar.com/library/AnyoneCanCook/paper.pdf
croissant.hipnc
On 2/7/2020 at 3:30 AM, konstantin magnus said:
Hi Masoud,
...You will need a lot of resolution to get thin walls. So it may be better to just do this inside a shader...
Hi "Konstantin",
Is it possible to do the same thing in a shader...?!
