animatrix Posted February 9, 2020 Share Posted February 9, 2020 http://patreon.com/posts/32631275 http://gumroad.com/l/houdinisupercharged In this video I will go through the GUI customizations I did for Houdini 18. So let's get into it. 2 Quote Link to comment Share on other sites More sharing options...
Librarian Posted February 9, 2020 Share Posted February 9, 2020 Yunus its this working in 16.5 ? Quote Link to comment Share on other sites More sharing options...
animatrix Posted February 9, 2020 Author Share Posted February 9, 2020 Hi Tesan, I tried with H17, sadly there was some glitches so I didn't bother porting it over. It's because Qt in Houdini is changing so much not just between versions but even between daily builds of the same version that I had to keep up with SESI to make sure it always works with the latest version. But if there is enough interest, I could look into porting it over Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted February 10, 2020 Share Posted February 10, 2020 @animatrix The network overlay the viewport is not too bad; if you can change the opacity of the network overlay based on the mouse wheel that would be good. Quote Link to comment Share on other sites More sharing options...
animatrix Posted February 10, 2020 Author Share Posted February 10, 2020 1 hour ago, CinnamonMetal said: @animatrix The network overlay the viewport is not too bad; if you can change the opacity of the network overlay based on the mouse wheel that would be good. Hi, yes this can be implemented easily but you will lose the wheel function for zooming in the network editor. But it could be added with a modifier key to keep the zoom function. 1 Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted February 18, 2020 Share Posted February 18, 2020 On 2/10/2020 at 2:14 AM, animatrix said: Hi, yes this can be implemented easily but you will lose the wheel function for zooming in the network editor. But it could be added with a modifier key to keep the zoom function. Is there plans to add this ? Quote Link to comment Share on other sites More sharing options...
animatrix Posted February 18, 2020 Author Share Posted February 18, 2020 Hi, no immediately plans to add that yet, because I need to see how to fit that into the whole system as a customizable thing so people can do anything they want with the mouse wheel as another customization. Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted March 7, 2020 Share Posted March 7, 2020 (edited) When it is added, update Edited March 7, 2020 by CinnamonMetal Quote Link to comment Share on other sites More sharing options...
