davilucho Posted February 21, 2020 Share Posted February 21, 2020 Hi all Im testing vellum blend for a personal work . I have attached a file where I inflate a torus and a pighead. I need to do it with a rest position so I have used a vellum blend to control of how start the geo animation and how it ends. With the torus works very well but if i use the pigheadtest is not working as expected. Torus and pighead has almost same size, points, and primitives. Is the pighead not working as expected because of the shape of the geo?? This is my question. If I apply a polyreduce to the pighead I start to get accurate results, but the things is that I want to do it with a high poly car model, so I would like avoid polyreduce to get good results. I have noticed that with high poly models is almost impossible to inflate using this method. Also Im trying to inflate by areas, I mean, per example inflate first the head of the pig and then the ears, in a gradual way. Can any one point me the right direction with this?? Thanks a lot for any help my friends inflating_test.hip Quote Link to comment Share on other sites More sharing options...
Noobini Posted February 21, 2020 Share Posted February 21, 2020 not on my Houdini machine atm but from memory, the hires pig oddly is hollowed at the bottom, try cap it first ? Quote Link to comment Share on other sites More sharing options...
davilucho Posted February 21, 2020 Author Share Posted February 21, 2020 Thanks for the reply Noobini. I tried that too, but still not working properly. Quote Link to comment Share on other sites More sharing options...
anim Posted February 21, 2020 Share Posted February 21, 2020 (edited) seems to be working fine it's not inflating fully simply because you currently have only "cloth" constraints so stretch and bend constraints, no pressure, no struts, no tets so in other words no constraints that are able to enforce the volume. Also your constraint iteration is fairly low by using Vellum Rest Blend your stretch and bend constraints are correctly adjusting their rest state so it's all up to their stiffness and constraint iterations * substeps so you can increase your iterations or substeps and bend stiffness to see how close you will get to the "inflation" that way, which may be enough for relatively low-mid res geo, but ultimately you may need to add at least struts, but probably better tet or pressure constraints Edited February 21, 2020 by anim Quote Link to comment Share on other sites More sharing options...
davilucho Posted February 25, 2020 Author Share Posted February 25, 2020 Thank yo very much for response. I did some changes in my geo in terms of mesh and is working perfectly. I also I have increase my substep as you said. Now my next goal is try in to inflate my geo by areas, i mean, not all the same time, first front area of the car, the nthe middle and finally the back. Lest see If i can get a good result. Thanks all. Quote Link to comment Share on other sites More sharing options...
ashu_tosh_m Posted June 11, 2020 Share Posted June 11, 2020 On 25/2/2020 at 7:10 PM, davilucho said: Thank yo very much for response. I did some changes in my geo in terms of mesh and is working perfectly. I also I have increase my substep as you said. Now my next goal is try in to inflate my geo by areas, i mean, not all the same time, first front area of the car, the nthe middle and finally the back. Lest see If i can get a good result. Thanks all. hey can u share that hip file im doing the same thing but its not working Quote Link to comment Share on other sites More sharing options...
