Accessing ptnum on a wrangle
davidyannick
Depending on what you're trying to do, you can either use the nearpoint() function which will return the closest point of the geo in the second input (to the point you're iterating on), or maybe you can setup a custom id attribute on both points, and then use the findattribval() function to find the corresponding point. Another possibility is to iterate through a point cloud, and there are many other way..
Cheers
