Vellum Age
garf
AFAIK, the standard vellum setup does not accept animated input, so @age is simply the frame number. You can assign an @id to the primitives and the solver will pass it through. Then you could post-sim process using a for loop to operate on each piece.
Here is Matt's setup with that modification.
ap_me_vellum_confetti_052020.hiplc
