Fuse edge to generate center line
Shamanek
Hi guys,
does anyone know if in Houdini is an option to fuse points in poly extrude to generate center line as I show in the gif below? Or how could we generate a center line in such a geometry?
I need to do it to generate neon light in the center of the letter.
No.
The problem is called Straight Skeleton. It is a well studied comptl geo problem. There is a robust implementation in CGAL, but it's most likely not an acceptable answer.
It's a hard problem that you can't just solve with a few chained SOPs sadly.
The closest you will have in Houdini is this: do a polyexpand SOP with those parameters: Output: Offset Surfaces
Offset: some large number greater that the dimensions of your object.
After that, finding the actual straight skeleton is not trivial either, because it is not a curve, but a tree. It does not exist as an object in Houdini.
You can have a look at the vertex attribute EdgeDist, in some cases it may help to delete some points to help you build the skeleton.
