Daniel16_16 Posted September 11, 2020 Share Posted September 11, 2020 Hello all I am trying to achive a twister sim with some particles. I have already set up the particle simulation and now I am trying to do the smoke simulation. But somehow the smoke is not following the particles or the smoke is going upwards. How to fix this problem that the smoke should go downwards and not upwards (see screenshots). And there is the hip file as well. Tornado_test1.hipnc Quote Link to comment Share on other sites More sharing options...
ronit1996 Posted September 11, 2020 Share Posted September 11, 2020 First thing, if you want to make a twister it will be better to just create a custom velocity field and drive your volumes through that not make a pop sim and then use it as a source for your smoke, i mean of course you can do that but I feel using custom vel field will be much easier plus you get the result with just one sim second thing is in current setup I believe you have temperature in your volume and that's why it's going up and not downwards kill the temperature and try to get the look with just velocity. Quote Link to comment Share on other sites More sharing options...
jonidunno Posted September 29, 2020 Share Posted September 29, 2020 This could help you too: https://www.tokeru.com/cgwiki/index.php?title=HoudiniDops#Tornado Quote Link to comment Share on other sites More sharing options...
Ultraman Posted September 29, 2020 Share Posted September 29, 2020 check hip file maybe help u to get what u want . twister.rar Quote Link to comment Share on other sites More sharing options...
Daniel16_16 Posted September 30, 2020 Author Share Posted September 30, 2020 Thank you, for your work and time, but i am a newbie in Houdini, And as I saw the node setup my heart has stopped beating haha xDD (thats much nodes!) But thanks again Quote Link to comment Share on other sites More sharing options...
Masoud Posted September 30, 2020 Share Posted September 30, 2020 If you are happy with your particle simulation the I suggest you convert the particles to volume... Quote Link to comment Share on other sites More sharing options...
