CurlNoise + Vex Help :(
Teteerck
Hi there! Houdini noob here ^^
Some days ago I found this image on the internet and I really liked it so I thought about trying to replicate it but maybe animating it hehe to me it seemed like it could be made using curl noise fields so I followed the entagma's vex 101 tutorial and I manage to make this little animation as a test, and I really liked it. I think is pretty close to the image, BUT i have 2 issues with it that i don't really know how to fix or adjust a little, so i was wondering is maybe some of you guys could help me a bit or at least guide me to the right path.
https://imgur.com/a/wyg2zMS
First: Looping it, is it possible to loop The curlnoise or the curlxnoise? Or is there any other noise function that would produce a similar result but easier to loop
Second: Is there any way to soften the curlnoise behavior in these spots? https://imgur.com/a/rLB40Hf
 My best idea so far i just placing the camera in a place where these intersections aren't in frame haha but would love to know if it's possible at least to make those somewhat less dramatic?
CurlNoiseTest_v1.hip
Edited by Teteerck
You could call the more extended version of curl noise directly. There is a periodic version that might help with the tiling. You need to include the voplib.h to access these extended functions, which are basically what VOPs wraps.
vector freq = chv("Frequency");
vector off = chv("Offset");
#include <voplib.h>
vector noise = vop_curlNoiseVP(@P, freq, off, { 0, 0, 0 }, "pnoise", "", 3, 0, 1, 0.5, 1, 1, 1, 0.0001);
// Laydown along an axis.
v@N = cross(noise,{0,0,1});
Run Over Numbers I like It make some Noise  ,Have Fun @Teteerck
float height(vector p; float f; float a){
        return a *anoise(p*f,3,0.1,1);
float dim = sqrt(@numelem);
 float f = 0.1;
 float a = 0.2 *dim;
 vector cur_p;
 cur_p.x = @elemnum% dim;
 cur_p.z = @elemnum/ dim;
 cur_p.y = height(cur_p,f,a);
 if (cur_p.x < dim -1 && cur_p.z <dim-1){
        vector next_p1;
        next_p1.x = (@elemnum+1)% dim ;
        next_p1.z = (@elemnum+1)/ dim ;
        next_p1.y = height (next_p1.y,f,a);
        float slopex = ( next_p1.y -cur_p.y)/(next_p1.x-cur_p.x);
        vector next_p2;
        next_p2.x = (@elemnum+1)% dim ;
        next_p2.z = (@elemnum+1)/ dim ;
        next_p2.y = height (next_p2.y,f,a);
        float slopez = ( next_p2.y -cur_p.y)/(next_p2.x-cur_p.x);
        vector n = set (slopex, 0, slopez);
        setpointattrib (0,"N",0,n);
        addpoint (0,cur_p/(dim-1));
#include <voplib.h>
Wow, thank you so much for the help! I ended up doing something similar just using a mountain node and i think i managed to do almost exactly what i wanted but i still looking how to loop it. I'm trying the blendshape node for that.
I tried this vex and loved the result! I didn't know about the extended noise functions, thank you again!
 float f = 0.1;
 float a = 0.2 *dim;
 vector cur_p;
        vector next_p1;
        vector next_p2;
Hi! Thank you so much for your help! I copied this code but I wasn't capable of making it work properly, should I just copy and paste? looking forward to seeing this in action. Thank you again so much!
