Convert curve to mesh overlapping mesh
Rival Consoles
Hello fellas,
I have been trying to create a simple shape using the curve sop and then the intention is to convert to mesh, extrude it and use the ray sop. However, once I convert the curve to mesh, some of the polys on the new mesh overlap each other. I have been trying so many ways to solve this but so far I haven't succeeded. Attached are the images showing what i'm seeing here.
Any help is much appreciated. Thanks!
Edited by Rival Consoles
not sure what you are using for converting curve to mesh, but this should work:
Curve SOP -> Resample SOP -> Remesh SOP
you can also link resample Length to Remesh Target Size to have equal edge lengths if you want
Hi @Librarian, thanks for that. I tried that as well but i get jagged edges on the side polys when I extrude the mesh. The nice thing about converting curves to meshes is that it gives a nice and clean quad topology. I guess a possible solution would be through editing the curves first, creating V crvs and then U crvs separately and then go from there. I'm trying to understand why is this happening in such a simple curve shape and what would be a solution to have clean quads out of it.
Modelling by hand would be very simple but still, i imagine that Houdini can handle that.
Cheers!
  • 2 weeks later...
Here is a solution based on PolyExpand 2D. The secret is to give the initial curve a shrinked version of itself.
The rest is just plumbing
The shrinked face (inside of top face at the end) will be ugly after the subdivision, but I guess it can be fixed by removing its shared edges if it's important downstream.
odforce.subdiv.hipnc
Edited by AntoineSfx
