hyunj16 Posted July 15, 2021 Share Posted July 15, 2021 Hi, I have a weird problem with Redshift in Houdini. I looked for solutions searching on Google but couldn't find it. I read Redshift documentation with Houdini plug-in and couldn't find it. If there is anyone who'd know what this problem is and know a solution for it, please help me out. So I created this simple scene with a text and a simple glass texture. I lit it and everything looked fine on Redshift RenderView (See attachment "Capture 1") I even enabled PostFX using Bloom. Color management is set to display "ACES" and Red.709 as "View" However, once I hit "Render To Disk", the MPlay window shows something way different even though it's set as "ACES" and "Red.709" (See attachment "Capture 2") It seems to have a different hue with higher vibrancy. The bloom is affecting the scene a lot more. Once I brought in the rendered exr sequence in After Effects, it looks a lot different than what I saw on MPlay -- which is supposed to be the same file. (See attachment "Capture 3") Not to mention, added "Bloom" effect is nowhere to be seen. Any Redshift experts out there who can help me out? Thank you. Quote Link to comment Share on other sites More sharing options...
ShkYo30 Posted July 21, 2021 Share Posted July 21, 2021 Hi! I don't use After Effect, but when I load my EXR sequence in DaVinci, the colors are weird too and I need to setup the "Rec 709" option with the calibration part to obtain the "good" colors. Maybe you have the same problem with AE, you need to precise the ACES options... Quote Link to comment Share on other sites More sharing options...
armin_lotfi Posted July 29, 2021 Share Posted July 29, 2021 (edited) When you bring your sequence in AE right-click on it and hit interpolate footage and in the color management pick ACES should be ok you can also download the OpenColorIO plugin for AE and load your OCIO config and you should be good I'm not sure about the bloom effect, if you're not seeing it in the output might be because you haven't checked the Post Effects option on your Redshift_ROP node but it's probably not that and will be fixed with changing the color management setting. If you're not getting the result that you want there is also an option for ACES in AE's Project Settings so make sure to check that as well Edited October 25, 2021 by armin_lotfi Quote Link to comment Share on other sites More sharing options...
ThomasEnglish Posted August 26, 2021 Share Posted August 26, 2021 I have been having this same problem for ages. Exactly like Jeong. My renders look like they are in a totally different gamma space to what I see in RenderView What is even weirder is the render via MPlay they initially render normally and then at the end it just flashes up by a load of gamma or exposure before moving onto the next frame. Off-course the output rendered is this bright version. Its annoying because you can colourcorrect it in EXR's but I am trying to do some jpeg renders. There is a redshift setting somewhere that is post modifiying the gamma and yeah I have check all post effects.. bloom etc come on smartly before this exposure jump. Quote Link to comment Share on other sites More sharing options...
Sepu Posted August 26, 2021 Share Posted August 26, 2021 if you want to render this postfx baked you have to add them postfx you need to have the first boxes checked by default they are not. However, I wouldn't recommend doing this but if you want that there go you. Quote Link to comment Share on other sites More sharing options...
ShawarmaBaby Posted October 10, 2023 Share Posted October 10, 2023 On 8/26/2021 at 6:48 PM, ThomasEnglish said: I have been having this same problem for ages. Exactly like Jeong. My renders look like they are in a totally different gamma space to what I see in RenderView What is even weirder is the render via MPlay they initially render normally and then at the end it just flashes up by a load of gamma or exposure before moving onto the next frame. Off-course the output rendered is this bright version. Its annoying because you can colourcorrect it in EXR's but I am trying to do some jpeg renders. There is a redshift setting somewhere that is post modifiying the gamma and yeah I have check all post effects.. bloom etc come on smartly before this exposure jump. Have you fixed this? I have the same problem, im not able to purchase a new redshift license and im stuck in 3.0.41 lol so i get this bug every render i make. its annoying Quote Link to comment Share on other sites More sharing options...
ftaswin Posted October 10, 2023 Share Posted October 10, 2023 After setting up OCIO properly and its loaded fine, Make sure you have Redshift Camera properties in you render camera for your render to look 1:1 to your disk renders Quote Link to comment Share on other sites More sharing options...
