Volume density based on point position and/or depth
I'm trying to figure out how to decrease a volume's density based on some value (say a point's position in space).
Say you have a sphere converted into a volume and a point at the center of that volume.
How do you go about calculating the volume's distance from that point and modifying the density based on that?
I would like the density to decrease the closer it is to the point.
I've tried volumesample(), volume gradient VOP node, and a few others...but I'm missing something.
Either VEX or VOP solution is fine.
Density decreases closer to the center...
Thanks!
Edited by TheDude123
Thanks for the links. After some testing, they work, but the falloff created is not linear (for the shape I'm using).
I would like the density to be highest on the outside of the box shape and fade towards the "center". What I'm currently getting is: dense, less dense, than dense again (see image). RED text from 0-1 is what I would like.
See .hip file and image below.
Thanks.
density_box_fade.hiplc
I noticed that increasing the resolution of the sphere seems to make the problem go away, but I'm not sure why that would make a difference
Edited by doc
