Grouping clusters and Isolation to create more detail
aliaq95
Hi guys,
So I have made a an overall form with sharp edges created in and around to what will be a spaceship/ procedural model. However, I can't seem to separate the group clusters separately to Poly extrude in their specific normals.
Thanks! First time posting here! :D
Space cruiser.hip
Hey guys, thank you for all the solutions and tips, super inspired by Akira Saito's work so I definitely wanted to build something. Will be continuing this and keeping posted on the progression of this! PS Not really fluent in VEX. Also don't know how to individually reply but Appreciate this community here! :D
Edited by aliaq95
  • 4 weeks later...
  • 3 months later...
2 hours ago, animatrix said:
If you have a prim attribute, you can use it to split the geo into separate pieces like this:
Aha thank you, then I misunderstood what the point split does, its purpose is to create clusters then?
In Akira Saito's presentation at 31:02 min. he is using the now depricated vertex split. (in the documentation it says we should use the point split instead, as you did).
https://www.youtube.com/watch?v=ghD79dVZZ_o&t=1766s
It seems to however be used to dissolve some vertices instead, maybe I am misunderstanding the footage.
Which ties into a question @Caskal once asked.
That's basically what I am trying to find out
Edited by crispr_boi
It's hard to see what he is doing from looking at that part, but if you want to split the geometry at arbitrary places by adding new detail along those edges across the faces, then I recommend this approach:
