New Houdini Tutorial
MIguel P
Great tutorial, Miguel!
I really liked the dust sprites in your 'road breaking' shot and thought it would be nice to see the way you've dealt with sprites shading and here goes your tutorial. You are reading my thoughts - please keep it going =)
Hehe.
Thank you.
I'm reading the tutorial again and there is a floattovector vop that does nothing in the shader...
Very useful indeed. Thanks for sharing and hope to see more.
One thing that bothered me though is the way the smoke trail stops still at the back. It really ought to be spreading out and drifting away a little. You can achieve that by adding a force with some turbulant noise based on AGE in to the POP network. Fading it out a little would probably help too.
Hello Miguel,
I did your great 'Meteor' tutorial, but I can't get the procedural shader to work.
I only get a black grid in the VEX editor.
Is it possible to post the VEX smoke shader, so I can test what I did wrong ?
many thanks,
bern
Edited by Bernard
Than you everyone, I'm glad you like it :)
Hello Miguel,
many thanks,
bern
Here is the otl with the shader.
SpriteSmokeShader.otl
spritevops.hip
Edited by MIguel P
Thanks MIguel, cool tutorial!
I have one question:
This setup links between the camera's position to the light's position (since the sprites always face the camera). However, I'd like to be able to put the light someplace else - to get nice shadows. Also, if I'll move the camera, the colors will change...
So, I tried to create a shader with constant lighting, but with shadows. I think I need to use the luminance loop for that, with the shadow operator, but I cant seem to make even a simple diffuse shader with the luminance loop, let alone add shadow to it.
Is there an example of such a thing somewhere?
Thanks,
Yaron
Thanks,
Yaron
Good idea! But I never tried that. I will try it.
  • 3 weeks later...
Hey Miguel, firstly a 'thank you' for posting the tutorial, its always a great help. I'm having a little trouble with the Meteor Tutorial in that whenever I get to the end of this section:
"5- Connect another Color POP and in the Alpha tab choose "Ramp". Write $LIFE in the Lookup
parameter. Put 3 keys and set the Alpha parameter to: Key1-> 0, Key2-> 1 and Key3-> 1. Put the
keys like in the following image.
6- Connect a Sprite POP to the color2 node, turn on the toggle for the parameter Scale and write in
both scale fields 0.5*($CA/2+0.5). This will make the particles increase their size using Alpha
attribute.
7- Press "d" to open the Display Options window and in the Particles tab, choose Display particles
as "Sprites". In frame 50 in your viewport you should see this:"
...I don't see the nice ramp colour on my sprites... I just see a constant yellow.
I was wondering if there is a step missing in the tutorial before this point, or if there is something that I should be doing in houdini to enable myself to see the nice yellow/orange/gray colour ramp on the sprites?
Thank you for your time, and the help.
Regards,
Sean
