jisun Posted August 23, 2023 Share Posted August 23, 2023 help!! Quote Link to comment Share on other sites More sharing options...
Jesper Rahlff Posted August 23, 2023 Share Posted August 23, 2023 (edited) here is one way to do it. you can lerp between the moved position and another position as you see fit volsample_and_gradient_example.hiplc Edited August 23, 2023 by Jesper Rahlff 1 Quote Link to comment Share on other sites More sharing options...
hannes603 Posted August 24, 2023 Share Posted August 24, 2023 (edited) Use a pyro simulation and drive particles with it . 'Advect by volume' or do that might be better volsample_and_gradient_example_Soft.hiplc Edited August 24, 2023 by hannes603 1 Quote Link to comment Share on other sites More sharing options...
Jesper Rahlff Posted August 24, 2023 Share Posted August 24, 2023 clever use of the ray sop! Thanks for sharing Quote Link to comment Share on other sites More sharing options...
jisun Posted August 25, 2023 Author Share Posted August 25, 2023 On 8/24/2023 at 2:12 AM, Jesper Rahlff said: here is one way to do it. you can lerp between the moved position and another position as you see fit volsample_and_gradient_example.hiplc 279.64 kB · 6 downloads Thank you for your wonderful answer. It was very helpful. Have a good day! Quote Link to comment Share on other sites More sharing options...
jisun Posted August 25, 2023 Author Share Posted August 25, 2023 18 hours ago, hannes603 said: Use a pyro simulation and drive particles with it . 'Advect by volume' or do that might be better volsample_and_gradient_example_Soft.hiplc 343.53 kB · 5 downloads Thank you for your wonderful answer. It was very helpful. Have a good day! Quote Link to comment Share on other sites More sharing options...
bunker Posted August 25, 2023 Share Posted August 25, 2023 also maybe check out this old thread Quote Link to comment Share on other sites More sharing options...
hannes603 Posted August 25, 2023 Share Posted August 25, 2023 @Jesper Rahlff your setup is also nice.. i played arround a little bit with it jetstream_volumesample_volume_gradient__curves_along_surface.hip Quote Link to comment Share on other sites More sharing options...
Librarian Posted August 25, 2023 Share Posted August 25, 2023 Plott.hiplc Quote Link to comment Share on other sites More sharing options...
Yader Posted August 25, 2023 Share Posted August 25, 2023 Or you could use Metaballs together with a Bulge. 1 Quote Link to comment Share on other sites More sharing options...
bengaet Posted August 25, 2023 Share Posted August 25, 2023 ive also played a bit to do it entirely in sops and vex, not really completed but it was a fun little experiment airflow_sops_vex.hipnc Quote Link to comment Share on other sites More sharing options...
