michael Posted February 18, 2003 Author Share Posted February 18, 2003 ok...really having trouble now.... in the help on L-systems it describes the ability to create groups like so: gF [ gFF] F the first and last F Quote Link to comment Share on other sites More sharing options...
edward Posted February 18, 2003 Share Posted February 18, 2003 If you middle click on the lsystem sop, you will notice that the generated groups are primitive groups, not point groups. Insert a group sop immediately after your lsystem and in the third parameter page (Edit), put down lsys1 for Group and Convert Name. Now your copy sop (after your group sop) will work. There might be a better way but that's the first thing I tried. Quote Link to comment Share on other sites More sharing options...
michael Posted February 18, 2003 Author Share Posted February 18, 2003 AH HA!!!! thanks edward... there was a little tickle in the back of my head but I didn't know what it was...and I even tried a group sop, but didn't realy investigate it at all...a little frustrated I guess... :| Quote Link to comment Share on other sites More sharing options...
michael Posted February 18, 2003 Author Share Posted February 18, 2003 a little update I even got wren to work Bone Test Quote Link to comment Share on other sites More sharing options...
michael Posted February 19, 2003 Author Share Posted February 19, 2003 more cool things happening... growing used rails and an align...the jitteryness is from the l-system...needs to figure out how to move the thing through the points instead of moving the whole thing... Quote Link to comment Share on other sites More sharing options...
stevenong Posted February 20, 2003 Share Posted February 20, 2003 Hey, That looks really cool!!! Have you tried using a Creep SOP instead? Cheers! steven Quote Link to comment Share on other sites More sharing options...
michael Posted February 20, 2003 Author Share Posted February 20, 2003 I'm using creep all over the place what I did in the above clip is to use a nurbs curve and a circle > copy the circle onto the curve then use an align to rotate and translate the circles so that the curve runs through their centers > then into a rails with an l-system as the cross section - much like the lightning tutorial - then into a polywire to get the shapes...to animate it I keyed the Right UV End value on the align... it's pretty damn cool, if I do say so myself but I'm not really happy with it... what I'd like to do is : instead of animating the 'growth' using the Right UV End value (which is really just moving the circles from 0 (all bunched up) to 1 (all spread out)) I'd like to have the l-systems grow from 0 to 1 but using the circles as guides...it's hard to describe - like an animated loft, but instead of a surface have some crazy-ass l-systems. I thought the rails op would do this, but either I'm not using it right or it just doesn't ... Quote Link to comment Share on other sites More sharing options...
FrankFirsching Posted February 22, 2003 Share Posted February 22, 2003 Hi! I noticed, that you posted already 2 links to the bmv pages, but only 2 sub pages. Here is the main site: http://www.cpsc.ucalgary.ca/Research/bmv/ But the most important page on this site is the one listing the publications: http://www.cpsc.ucalgary.ca/Research/bmv/p...pers/index.html The paper Visual models of plant development of Przemyslaw Prusinkiewicz (the most important person, when it comes to L-systems nowadays) is a great resource. It describes on 68 pages the use of different L-systems with plenty of examples. I used it to prepare a seminar-talk at university. Hope you didn't know it already Frank Quote Link to comment Share on other sites More sharing options...
michael Posted February 22, 2003 Author Share Posted February 22, 2003 thanks Frank...I didn't have the main page bookmarked I find the U of C site difficult to get around in...much like the campus...LOL Quote Link to comment Share on other sites More sharing options...
eigen Posted February 23, 2003 Share Posted February 23, 2003 Hi folks, i Quote Link to comment Share on other sites More sharing options...
FrankFirsching Posted February 23, 2003 Share Posted February 23, 2003 Hi! You can pipe your leave direct into the L-System SOP and place copies of it as Houdini builds up the tree. The first input is the J, the second the K and the 3rd input is the M-leave. To place a leave simply drop a J, K or M into the rules, which describe your tree. Houdini takes care of rotating and scaling the leaves to accomodate the current twig-sizes. Frank Quote Link to comment Share on other sites More sharing options...
michael Posted March 2, 2003 Author Share Posted March 2, 2003 oooppps!..hehe made a little error but it looked cool so....calling Dr. Seuss Quote Link to comment Share on other sites More sharing options...
platypus Posted March 3, 2003 Share Posted March 3, 2003 it's a Fern Shrub. Quote Link to comment Share on other sites More sharing options...
Stremik Posted March 9, 2003 Share Posted March 9, 2003 Hey arctor. Say. What was the problem that started this thread? How did you fix it? I'm having same issue but I can't figure out what's wrong. Quote Link to comment Share on other sites More sharing options...
platypus Posted March 9, 2003 Share Posted March 9, 2003 If I read you right, you are having the problem with getting the pruned growth l-system tutorial to work... if that is the case, you just have to make sure that you have the merge1 going into the far right input of the l-sys. looks like the image that they provide in the docs is incorrect. hope that helps. Quote Link to comment Share on other sites More sharing options...
Stremik Posted March 9, 2003 Share Posted March 9, 2003 Great! It works.(the metatest input ) Thanks. Quote Link to comment Share on other sites More sharing options...
michael Posted March 9, 2003 Author Share Posted March 9, 2003 damn.... the one question I'm able to answer here and I get beat to it :| Quote Link to comment Share on other sites More sharing options...
platypus Posted March 9, 2003 Share Posted March 9, 2003 sorry arctor. didnt mean to step on any toes. you should just be glad that you werent the one hanging out on the message board on a saturday night. Quote Link to comment Share on other sites More sharing options...
michael Posted March 9, 2003 Author Share Posted March 9, 2003 LOL... it might have been better than what I was doing...a friend of mine and I went to MacDonalds with his 2 kids (2yrs and 3yrs) Quote Link to comment Share on other sites More sharing options...
Carlos Posted March 10, 2003 Share Posted March 10, 2003 Can length be sepecified as to how far "F"orward you want to go? Quote Link to comment Share on other sites More sharing options...
