Brick/Stone Wall - Broken Horizontals
michael
here a fun(?) little problem...
given the following reference
http://donnamarie113.deviantart.com/art/BRICK-WALL-298282838
http://www.desktopwallpapers4.me/abstract/brick-wall-and-wood-floor-14568/
http://fc03.deviantart.net/fs70/f/2013/054/e/4/brick_wall_by_kayosa_stock-d5vy7u3.png
how would one go about building a wall like this - a brick/stone wall is VERY easy...but a wall with what I'm calling 'broken horizontals' is much more difficult...
if/when I have some time I'll see what I can do and post my results...if anyone has some good suggestions :)
hmmmm
a series of divides - no convex, bricker polys with random values gets part of the way...
anyone know why a group SOP (by expression -> rand($PR) in a foreach would only work once?
Maybe it's just returning the same random number each iteration? Try something like rand(($PR*stamp("../../foreach1", FORVALUE, 0)))
  • 2 weeks later...
  • 2 weeks later...
Thanks, guys
It is all done with standard Voronoi.  The only difference is how you treat the second input (cells).  Some people just chug a point cloud and get a cell per point.  A more sophisticated solution is to turn  Voronoi SOP's clustering with "Add Cluster Noise", but that gives you... a noisy pattern which is ok for generic break-ups, but is hard to control.  What you do want is to control the cluster shapes.  Say, you've got a point cloud and it is is clustered, i.e. every point has attribute "cluster", type integer. For a Voronoi SOP, set "Cluster Pieces" on and feed your point cloud to Voronoi SOP.
As for "teris" or lego-like look is due to a regular point-cloud (i.e. grid-like) with an addition of a few extra scattered points. It's a lot of fun to play with Voronoi in order to achieve various shapes.  The notorious "Voronoi-look" is not the fault of the algorithm, but of the input ;)
Cheers,
Vladimir
Edited by MADjestic
  • Like 3
Those are really nice results. I've played with more regular seed point distribution before, but haven't combined them with clustering yet.
Now figure out a way to add space between each 'brick' so you can add concrete to the wall :).
well if it isn't little Matty Estella...
:) nice results....
I haven't had time to get back to this in a while but there are some very cool ideas here, thanks...
I really want to break open Substance Designer and figure out how it's tile generator works...
  • 5 months later...
  • 1 month later...
Really cool technique! Not that I ever play around much with Voronoi, but never knew this functionality existed.
This is Vlad's setup fed into a ForEach based on the name attribute, generate a random noise seed inside with `stamps("../", FORIDXVALUE, 0)`, subdivide each piece, then use that seed to add a little Unified Noise variation to @P.y.
VDB -> Poly after just to surface it nicer.
I feel like you could mess around for a month with this general idea and keep coming up with new stuff.
tetris.hipnc
  • Like 8
