How To Make an Animated GIF For The Forum
Atom
Hi All,
I know this sounds incredibly simple and I thought the default box node would do this but I am having trouble. I am trying to re-create the C4D Matrix object in Houdini. Basically the C4D Matrix object is a 3D grid of points. I thought I could just subdivide the box but that only gives my points along the faces of the box/cube. I need points through out the entire volume of the box.
How would I set this up?
Thanks
PS: Seeing how the thread was hi-jacked for another topic I renamed it.
Edited by Atom
@eetu: I did try that initially but the divisions parameter only subdivides the points that fall on the faces so I ended up with no points inside the box at all. I thought it would work like the grid does.
