GPU and Mantra?
rohandalvi
  On 10/25/2015 at 4:23 PM, malexander said:
Have you tried the GL ROP in H15? The more serious issues with it have been resolved (transparent objects, material issues, BG image support).
Definitely appreciate the work done there, it was the second thing to check after the FEM improvements, motionblur and dof are as critical too to bring it up to the flipbook level.
The current flipbook dof & moblur are built into the flipbooking system, not the viewport. They also predate any sort of GL shader work, so there are much better ways to do both (quality and performance-wise). It's on the todo, it lost out to Onion skinning this time around.
Well if at some point would be possible to get a decent approximation of the mantra render in the viewport this would be great to block the lighting and use it as a tool to approve lighting before fully rendering the shot in Mantra.
This would be so useful
This is why a master class in the viewport/glsl would be wicked - glsl can do so much and a kickstart would be great to get the community going.
when you see what sketchfab guys can display in a webgl viewport
https://labs.sketchfab.com/siggraph2014/viewer.html?model=devastator
even for transparency you have cheats :
http://madebyevan.com/webgl-water/
i guess that you can definitly get some kickass accuracy beetween a Mantra PBR render and a OpenGL 3.2 PBR viewport.
considering that the set of possibility offer by OpenGL 3.2 beats hands downs the very limited WebGL sets of function.
And i agree that realtime previz would beat hands down any GPU previz stuff for efficiency ...
Edited by sebkaine
I hope H16 will have materials with some decent representation in the viewport, compared to the final render in Mantra.
If at least the "speculars BSDF shapes" are similar then it will be very useful.
  On 11/5/2015 at 6:26 PM, marty said:
An omen perhaps...   :)
'Redshift wins CG Awards’ new application award'
This year’s runners up were Autodesk Memento, The Foundry’s NUKE STUDIO and Houdini Indie.
https://www.redshift3d.com/blog/redshift-wins-cg-awards-new-application-award
Good that NukeStudio didnt win, bugfest galore
  • 5 months later...
  • 8 months later...
  On 1/6/2017 at 4:20 PM, lukeiamyourfather said:
So four Phi cards that cost around $10K (not including the rest of the computer) are on par with really old Xeon processors. I don't get why anyone would want to do this.
Expand
in the cinebench the render wasn't optimized(compiled) for the xeon phi, there are some optimizations options open, so it didn't show the full power.
on page 19 there is a compairing of two systems with the embree renderer:
https://embree.github.io/data/embree-siggraph-2016-final.pdf
if the render is optimized it will be in the same speed range of a 2x E5-2699(2.3Ghz / 18core) system
Edited by Mandrake0
