Toms "Learning Houdini" Gallery
Thomas Helzle
Just now, jkunz07 said:
Very nice!  How did you derive the curve normals for the spec highlight?
In a mantrasurface you dive into the network after making it editable and then replace the two normal inputs in the main surface node with the output of a "Hair Normal" node, that will give it a roundish look.
Cheers,
Tom
  • 2 weeks later...
  • 4 weeks later...
14 hours ago, Thomas Helzle said:
"Sutur Fluid Painting"
Using another GLSL shader as Displacement in Houdini:
Hello Thomas, big fan of your stuff, I started learning mantra, would love to know some tips on how to achive this stuff, really loving the flow and colours, cheers!
This one is heavily post-processed in Photoshop with the "Oilpaint" filter. If you deactivate it's specular component, you basically get a directional blur which sometimes works great on images with clear lines.
The displacement texture is a modified version of this GLSL shader: https://www.shadertoy.com/view/XddSRX
I currently look into GLSL using this IDE: http://synthclipse.sourceforge.net/index.html
Otherwise its a simple displacement on a grid :-)
Cheers,
Tom
Cheers,
Tom
Thanks a lot for the info! That shadertoy site is awesome, lots to learn.
One last question, on the shader toy site there are 2 codes (Buf A and Image), by curious I tried putting in a wrangle but didnt work, there is any way to translate this stuff to houdini?
Will read more about these sites, thanks again! and keep sharing your art!
Cheers
Cheers
I made a big screenshot of the result after some time of painting in synthclipse... ;-)
There is a GLSL node in Houdini, but I think I read somewhere that it's for the viewport only.
Can't help you there, I haven't tried it yet.
Cheers,
Tom
