wrapping geo like Wrap3
Seems like an advanced tool for me. I think it's not possible in Houdini, unless you'll write such solver from scratch using basic Houdini tools. You need to know algorithms behind this technology. Ray SOP basically does a raytrace. It is somewhat useful to conform meshes with almost identical shape, but it won't give you advanced results like transforming a base state of modeled hand into a gesture from scan. Same problem with point clouds.
  • 2 years later...
  • 2 weeks later...
Alright so I just finished to study python (solo learn app ftw) to figure out how the python code works. For those interested:
node = hou.pwd()
geo = node.geometry()
#these came by default with Python SOP, don't change it.
nodeTrans = node.node("/obj/geo1/subnet1/objnet1/OUT")
#nodeTrans receives the points and its data resulted of the objnet/extractgeo SOP
mat = nodeTrans.worldTransform()
#mat receives a matrix with the transform data of the points in the world, translate and rotate information
matAttrib = geo.findGlobalAttrib("mat")
#matAttrib receives the 'detail attribute' data from mat. In the first time in the loop it has zero data, so \/
if not matAttrib:
    matAttrib = geo.addAttrib(hou.attribType.Global, "mat", mat.asTuple())
#Turns the matrix data of mat in 'detail attribute' as Tuple
else:
   geo.setGlobalAttribValue(matAttrib, mat.asTuple())
#if matAttrib already has something in it, put these values into 'detail attribute'
