Pancho Posted March 2, 2017 Share Posted March 2, 2017 I have the feeling that my workflow and Houdini's feedback on my input/commands is much slower than with previous version. Moving the mouse over the top menu and there is a lag of about 0.5 - 1.0s till the menu gets highlighted. Press tab and type in the name of a node and there is the same lag, sometimes even worse, 1-2s. I updated the nvidia drivers to the newest one. Sometimes I read in the lower left corner "Evaluating python". No idea where this comes from. As much as I love the update, working with is so far feels horrible. Can't believe that there should be such a difference in speed on the top level of H between both versions. Cheers Tom Quote Link to comment Share on other sites More sharing options...
Atom Posted March 2, 2017 Share Posted March 2, 2017 I agree Houdni 16 is bloated and slower. I mean who wanted all that silly eye candy anyway? I find a radial menu on every node to be excessive. Quote Link to comment Share on other sites More sharing options...
Pancho Posted March 2, 2017 Author Share Posted March 2, 2017 Yep. Point is, how can I bring it back to speed? Got two Titans Black inside the PC and the best new chips available are just twice as fast as my current one. So, this won't work. Stunned that nobody else is complaining?!?! Quote Link to comment Share on other sites More sharing options...
michael Posted March 2, 2017 Share Posted March 2, 2017 you should send in a bug report https://www.sidefx.com/bugs/submit/ and newest drivers are not always better drivers the node ring can be turned off (or set to appear only at a distance) - hit "d" in the network, first option Quote Link to comment Share on other sites More sharing options...
Atom Posted March 2, 2017 Share Posted March 2, 2017 The viewport does seem to be the culprit. I notice I can no longer load hi-res meshes in Houdini. This is what it is famous for. I get better performance out of Marvelous Designer on the same hardware with the same .OBJ, compared to Houdini. I have even tried turning on Remove Back Face Culling. I get the feeling that there is still a single-core process involved that has to loop over all the points. That process should be multi-threaded. Quote Link to comment Share on other sites More sharing options...
Guest tar Posted March 2, 2017 Share Posted March 2, 2017 2 hours ago, Pancho said: Yep. Point is, how can I bring it back to speed? Got two Titans Black inside the PC and the best new chips available are just twice as fast as my current one. So, this won't work. Stunned that nobody else is complaining?!?! The Qt4 version is butter smooth on MacOS whilst the Qt5 version degrades over time to the point where the pop-up window buttons no longer are clickable. Quote Link to comment Share on other sites More sharing options...
malexander Posted March 2, 2017 Share Posted March 2, 2017 Have you tried a daily build of Houdini 16? Several viewport performances issues were fixed in the days leading up to the release which didn't make the gold release build itself. Quote Link to comment Share on other sites More sharing options...
Atom Posted March 2, 2017 Share Posted March 2, 2017 I'll give that a try as soon as Redshift irons out a bug with using the exporter on a daily builds. It works with the production build already, however. Quote Link to comment Share on other sites More sharing options...
johnm Posted March 2, 2017 Share Posted March 2, 2017 7 hours ago, Pancho said: ...Moving the mouse over the top menu and there is a lag of about 0.5 - 1.0s till the menu gets highlighted.... helpful little tip for people who hate waiting for the tooltip info that pops up when you hover over a shelf tool, or parameter, etc.... if you hold the CTRL key while you hover, the tooltip pops up instantly. 4 Quote Link to comment Share on other sites More sharing options...
TobiasSteiner Posted March 5, 2017 Share Posted March 5, 2017 (edited) Just tested 16.0.537. Still crappy UI performance if trying to use two monitors. Ugh, I'm so bummed out about this release. Looks like I won't be getting any use out of this release until I can get my hands on a wicked expensive video card. SESI is really crapping on my world right now. Really took the wind out of my sails. Edited March 5, 2017 by TobiasSteiner wrong version number Quote Link to comment Share on other sites More sharing options...
6ril Posted March 5, 2017 Share Posted March 5, 2017 I tested it on linux, and immediately got annoyed by the laggy experience. I blamed my video drivers, but now that I read this thread... staying on 15.5. (and mad to miss on that awesome boolean tool). Quote Link to comment Share on other sites More sharing options...
axalon Posted March 5, 2017 Share Posted March 5, 2017 5 hours ago, TobiasSteiner said: Just tested 16.0.537. Looks like I won't be getting any use out of this release until I can get my hands on a wicked expensive video card. Have a GeForce 1070 and am still experiencing viewport lag, so I don't think it's just your viewport Quote Link to comment Share on other sites More sharing options...
mohamaedkamal Posted March 5, 2017 Share Posted March 5, 2017 (edited) I think u can turn off display material in viewport , Edited March 5, 2017 by mohamaedkamal Quote Link to comment Share on other sites More sharing options...
Guest tar Posted March 5, 2017 Share Posted March 5, 2017 20 hours ago, TobiasSteiner said: Just tested 16.0.537. Still crappy UI performance if trying to use two monitors. Ugh, I'm so bummed out about this release. Looks like I won't be getting any use out of this release until I can get my hands on a wicked expensive video card. SESI is really crapping on my world right now. Really took the wind out of my sails. Did you test 1 monitor instead of 2? Did you test test the Qt4 version as well? Quote Link to comment Share on other sites More sharing options...
Guest tar Posted March 5, 2017 Share Posted March 5, 2017 (edited) On 03/03/2017 at 3:33 AM, Atom said: I agree Houdni 16 is bloated and slower. I mean who wanted all that silly eye candy anyway? I find a radial menu on every node to be excessive. I'll just throw in that I disagree with these types of statements - H16 is large step forward in usability and being a pleasant UX and UI. EDIT: though I'm sure we'll all keep this in mind next time you have an issue trying to run h16.. that is if we want to help you or not... Edited March 5, 2017 by tar Quote Link to comment Share on other sites More sharing options...
DaJuice Posted March 6, 2017 Share Posted March 6, 2017 Hmm, I can't say that I have noticed any performance difference in the UI from previous versions. I tried the QT5 16.0.538 windows build at work earlier on a triple display setup. Worked fine, no issues. I believe that machine has a GTX 680. At home I have a Quadro 4000 in my machine and I'm not seeing any lag here either. Quote Link to comment Share on other sites More sharing options...
Johannes Posted March 6, 2017 Share Posted March 6, 2017 Im also feeling the slowdowns in H16. For me it's packed geos that sometimes give me less FPS, removing packed and the FPS goes up. 15 and 15,5 was all fine. Is it just me, or is anyone else having this little issue? Quote Link to comment Share on other sites More sharing options...
Pancho Posted March 8, 2017 Author Share Posted March 8, 2017 I just wanted to download the latest version and discovered the H16 with QT4 support beneath the main download link. Which version for which purpose??? QT4 = Quicktime 4? Cheers Tom Quote Link to comment Share on other sites More sharing options...
Noobini Posted March 8, 2017 Share Posted March 8, 2017 big Q, little t....not Quicktime....just lookup Qt5 Quote Link to comment Share on other sites More sharing options...
Pancho Posted March 8, 2017 Author Share Posted March 8, 2017 Thanks, but which version do I need? No explanation on the download site. Quote Link to comment Share on other sites More sharing options...
