Hayden Posted April 4, 2017 Share Posted April 4, 2017 I have a load of RBD packed objects smashing on a Ground Plane, they're all intersecting by a consistent distance through the Ground Plane, the RBD packed objects are all convex hull rather than concave although changing between the two doesn't seem to make a difference. I've tried replacing the Ground Plane with a static box and trying different geo representations on it but that doesn't seem to work either. Any suggestions on how to fix this would be really appreciated! Thanks Quote Link to comment Share on other sites More sharing options...
michael Posted April 4, 2017 Share Posted April 4, 2017 without seeing you file it's just a guess but - it's probably a collision geo issue. turn on Show Guide Geometry to see the blue collision geometry 1 Quote Link to comment Share on other sites More sharing options...
Hayden Posted April 7, 2017 Author Share Posted April 7, 2017 On 4/4/2017 at 7:18 AM, michael said: without seeing you file it's just a guess but - it's probably a collision geo issue. turn on Show Guide Geometry to see the blue collision geometry Thank you for the reply! I understand its difficult without the scene file, i haven't attached it because it has upwards of 30 models in it that i have read in from elsewhere. i have turned on guide geometry on everything and it is displaying as fine, everything has correct guide geometry where the faces are blue. I still dont understand why the collision geo does seem to be working but just not 100% This is still an ongoing problem so if anybody reading this thinks they may know something that would help it would be greatly appreciated Quote Link to comment Share on other sites More sharing options...
Gavin Posted April 7, 2017 Share Posted April 7, 2017 If you want to make your objects overlap less you can try playing with your collision padding and shrink amount. By default these fields are linked, so increasing your padding won't have much effect on the exterior padding of the object. However if you turn off the shrink amount, or break the connection between the two and dial them in separately you might find a good ratio for your sim. Quote Link to comment Share on other sites More sharing options...
Noobini Posted April 8, 2017 Share Posted April 8, 2017 (edited) so far the only way I can mimic this effect is to put the Number of SubSteps in rigidbodysolver down to a ridiculously low 1 (from default 10) Edited April 8, 2017 by Noobini Quote Link to comment Share on other sites More sharing options...
Hayden Posted April 8, 2017 Author Share Posted April 8, 2017 7 hours ago, Noobini said: so far the only way I can mimic this effect is to put the Number of SubSteps in rigidbodysolver down to a ridiculously low 1 (from default 10) Thank you for the reply, i tried putting the substeps up but it hasn't seemed to make much of a difference, i have done a mock scene where the same problem is happening if anybody could have a look? IntersectingGeo.hipnc Quote Link to comment Share on other sites More sharing options...
Atom Posted April 8, 2017 Share Posted April 8, 2017 (edited) I would not expect a lot of accuracy out of Bullet, it is game engine technology. Try constructing your scene using RBD instead. Edited April 8, 2017 by Atom 1 Quote Link to comment Share on other sites More sharing options...
Noobini Posted April 8, 2017 Share Posted April 8, 2017 got it !!! your Dopnet has a Transform on it...Zero them out and she'll be right.....tho you would've thought it's more on the Y axis that's the real problem...weird... Quote Link to comment Share on other sites More sharing options...
Hayden Posted April 9, 2017 Author Share Posted April 9, 2017 7 hours ago, Noobini said: got it !!! your Dopnet has a Transform on it...Zero them out and she'll be right.....tho you would've thought it's more on the Y axis that's the real problem...weird... WOW i feel stupid Thank you for the fix! I think in future a good nights sleep might save me a lot of time Quote Link to comment Share on other sites More sharing options...
