FIRE IGNITION - TOO SLOW
Brickouz
Hello!
I'm animating a  burning match, and here is my problem :
The ignition starts too slowly, even if I set up a fast fire.
Is there a way too fix this? This is the kind of ignition I would like to make :
Thank you!
Thank you, but this doesn't work, I think I haven't been able to give a good description of my problem.
When I light the fire, the match is moving fast, and so is the fire source. I think the problem is that when it is moving too fast the fire is not burning well. Is there an option who help the fire to avoid cooling down?
Hard to say, need to see the scene, share an example.
I see a couple ways:
1) Play with timescale and combustion
2) Using repeat solver (https://vimeo.com/164664923)
