hallogero@gmail.com Posted May 13, 2019 Share Posted May 13, 2019 Thank you for your quick answer Alexey! I’m looking forward to the release Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted June 4, 2019 Author Share Posted June 4, 2019 (edited) DM 1.5 released. What's new: 1. SoftBoolean 1.1 - UI improvements and small optimizations, groups preservation, new soft-boolean tools 2. Geometry Library 1.5 - add elements by the construction plane, filter items with mask, UI revamped 3. Menu - fully redesigned menu subsystem. User can now create custom menus with submenus by using a simple Python syntax 4. Menus are now fully customizable and works much better with HiDPI displays 5. Shelf fully redesigned 6. All tools and HDAs have icons 7. Quick Deform revamped. Added new tools: View Deform, Size Deform, Ramp Deform 8. Lots of new modeling HDAs 9. Python code is now open 10. Works with Houdini >= 17.5 11. Modeler - a brand new mode for classic polygonal modeling Early DM 1.5 beta in action: https://youtu.be/0tWJdtk1z0Q Gumroad link: https://gum.co/GVLLS Edited June 4, 2019 by Alexey Vanzhula Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted June 7, 2019 Author Share Posted June 7, 2019 (edited) DM 1.5 for Houdini. 3 days discount! https://gum.co/GVLLS/dm_discount Edited June 7, 2019 by Alexey Vanzhula 1 Quote Link to comment Share on other sites More sharing options...
eyeclick Posted June 8, 2019 Share Posted June 8, 2019 QLight is awesome!!! Thank you. 1 Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted June 14, 2019 Author Share Posted June 14, 2019 DM 1.5 release video: https://vimeo.com/342214408 Quote Link to comment Share on other sites More sharing options...
hallogero@gmail.com Posted June 16, 2019 Share Posted June 16, 2019 Awesome tool! Thank you for the update! Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted July 1, 2019 Author Share Posted July 1, 2019 (edited) DM 1.5 discount 20% v1.5.14 What's new: 1. A new Tools Widget - a place where you can call the tools or learn the hotkeys 2. New tools 3. MacOS support https://gumroad.com/l/GVLLS/discount Edited July 2, 2019 by Alexey Vanzhula Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted July 11, 2019 Author Share Posted July 11, 2019 Set Flow SOP preview: 1. https://vimeo.com/347248950 2. https://vimeo.com/347476024 2 Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted August 19, 2019 Author Share Posted August 19, 2019 DM 2 for Houdini released! Product link: https://gum.co/xKBKM What's new: General changes: 1. Soft Boolean 2.0: 1.1. Revamped core 1.2. Revamped UI 1.3. Better fillet build algorithm 1.4. Smart normals allows to get very nice models without tweaks 1.5. Faster then Soft Boolean 1.*, despite it always builds normals 1.6. Different analyzation modes 2. Insert Mesh 2.0 now uses smart normals, which leads to much cleaner results 3. Geometry Library 2.0 allows to save models with materials 4. Lots of DM HDAs fixes Modeler 2.0: 1. Edge Flow can be used to set flow for selected edges or using, previously inserted, multiply edge loops 2. Push tool now highlights edge under the mouse pointer, which leads to much stable use of RMB menu tools 3. Push tool can set flow for highlighted edge or loop 4. Flatten menu (Alt+F) now uses gestures. It is a very fast way to flatten components by left, right, top or bottom directions 5. You can now convert selected edges to loops with A+RMB hotkey 6. Align view is now works like in 3dCoat or ZBrush. Press Shift while rotating the viewport camera 7. ToolsPanel (Spacebar key) has now a "Custom" section - a place where you can use custom scripts or stock Houdini tools 8. "Relax Selection" tool, applied to edges, now uses a new Smooth Edges HDA. It allows to smooth selected edges as separate curves 9. More uses of mouse wheel in some modeling states 10. Extrude tool can now extrude edges in screen space or using Shift and Ctrl to move by the best axis 11. Selector is a powerful fast way to select geometry by features like, component normal or vertex count etc 12. "Pick Duplicate Material" tool can be used to quickly select material from face and assign it's copy 13. Extrude and MoveExtrude tools are now combined 14. Inset tool removed, use Extrude instead 15. Modeler menu now has more tools 16. Some hotkeys changes Modeler Topo: 1. New tools category "Topo" 2. Can be used to quickly create retopology of high-poly models 3. Use any of modeling tool and finish edits with a Project tool 4. Special red cursor indicates that you are in Topo mode 5. Native retopology tools are now better integrated into Modeler and Modeler menu 6. F1-F6 keys can be used to switch between TopoBuild SOP modes without actual state activation 7. Special TopoStripe tool can speedup retopology stage with drawing ribbons and circles Modeler UVs: 1. New tools category "UV" 2. "UV Auto Flatten" HDA automatically creates UV map. Can be used in combination with Unwrap and UV Layout tool 3. Unwrap HDA 3.0 is now integrated to the Modeler mode. Use Ctrl+RMB or Connect tool (V) to pick edges without needs for pressing buttons in the Parameters pane 4. Connect tool (V), called in UV viewport, sew edges interactively 5. MMB, Shift+MMB, Ctrl+MMB can be used to transform UVs quickly 6. Flatten menu (Alt+F) can be used to flatten UVs by left, right, top or bottom directions 1 Quote Link to comment Share on other sites More sharing options...
zarralax Posted August 20, 2019 Share Posted August 20, 2019 Hi Alexey, Last year you said the upgrade from DM1 to DM 2.0 was going to be free, how do current DM users get the new version? thanks 2 Quote Link to comment Share on other sites More sharing options...
Njordy Posted August 21, 2019 Share Posted August 21, 2019 (edited) On 8/20/2019 at 5:14 AM, zarralax said: Hi Alexey, Last year you said the upgrade from DM1 to DM 2.0 was going to be free, how do current DM users get the new version? thanks No, they don't. He has backed down from that claim, it's a paid update now. Everyone who was waiting for free 2.0 should enjoy 1.5. EDIT: Apparently, he's getting notifications from this forum in minutes, guys. And he didn't like what I briefly said the current state of things, and answered the question he doesn't like answering. Edited August 21, 2019 by Njordy To attach a file about this post. Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted August 21, 2019 Author Share Posted August 21, 2019 So, now you know that you don't right. Maybe you have to delete this anomal post Quote Link to comment Share on other sites More sharing options...
Njordy Posted August 21, 2019 Share Posted August 21, 2019 2 minutes ago, Alexey Vanzhula said: So, now you know that you don't right. Maybe you have to delete this anomal post I don't see no "anomal" post, and I don't think what I'm wrong about anything I've said. Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted August 21, 2019 Author Share Posted August 21, 2019 You sick 1 Quote Link to comment Share on other sites More sharing options...
Njordy Posted August 21, 2019 Share Posted August 21, 2019 37 minutes ago, Alexey Vanzhula said: You sick No-no, I'm pitty. Pretty pitty man. Dude, just ___ it. Let's not blow it out of proportions any more. You keep making tools and money, I enjoy my glamorous version 1.5. I don't think you are right, and have lots of point why, you not gonna change your mind or attitude. Period. Quote Link to comment Share on other sites More sharing options...
bobc4d Posted August 22, 2019 Share Posted August 22, 2019 On 8/19/2019 at 9:14 PM, zarralax said: Hi Alexey, Last year you said the upgrade from DM1 to DM 2.0 was going to be free, how do current DM users get the new version? thanks I seem to remember same thing. there is a discount. Quote Link to comment Share on other sites More sharing options...
Njordy Posted August 22, 2019 Share Posted August 22, 2019 5 hours ago, bobc4d said: I seem to remember same thing. there is a discount. Check you email. Everyone got $30 discount two days ago. Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted August 22, 2019 Author Share Posted August 22, 2019 Quote Link to comment Share on other sites More sharing options...
Njordy Posted August 22, 2019 Share Posted August 22, 2019 8 hours ago, bobc4d said: I seem to remember same thing You don't need to remember. You could just scroll back to first pages of this thread... oh, but no, you can't. Today he's deleted all his posts from April to July period. Good thing is, I always make screenshots of everything. Quote Link to comment Share on other sites More sharing options...
ghiom Posted August 22, 2019 Share Posted August 22, 2019 HEllo , i was very surprised when i discover today you change the deal we made Alexey ! We deal : DM 1.0 (with possibility of updating to 2.0) for an amount of money. No you have change the deal . It's not this way that work. You cannot change the deal by your own. you have to ask everyone wich have do this deal with you to find a new deal. You are not D.TRUMP, don't act like him. it's not business it's bullshit. If you respect your community, it will grow like you never expect. If not, you will loose it. You can ask in gumraod to people to give what they want by explaining that it was a lot of work more than expected and you need money. I'm sure people like me are ready to support someone wich work hard. you gain support and credibility this way. 2 Quote Link to comment Share on other sites More sharing options...
