frokito Posted June 21, 2018 Share Posted June 21, 2018 (edited) This effect at 0:16-0:20 is inspiring me to learn houdini. But what is called and how do I achieve this effect Edited June 21, 2018 by frokito Quote Link to comment Share on other sites More sharing options...
toadstorm Posted June 21, 2018 Share Posted June 21, 2018 looks to me like the effect is called "rotating a bunch of things and then meshing them together". learning how the copy SOP works with template point attributes, and how VDB surfacing works, are probably your main goals for this. 1 Quote Link to comment Share on other sites More sharing options...
merlino Posted June 21, 2018 Share Posted June 21, 2018 I don't know if it has some name, but it seems they are working on the primitives that compose the geometry, transforming them with the "primitive" node. I think that's the easy part ... Before that you should make points uniques and after that fuse the geometry again. Maybe this is a good start. Good luck! Quote Link to comment Share on other sites More sharing options...
kiryha Posted June 21, 2018 Share Posted June 21, 2018 Quote Link to comment Share on other sites More sharing options...
jonidunno Posted June 26, 2018 Share Posted June 26, 2018 This should help too. Quote Link to comment Share on other sites More sharing options...
Midphase Posted June 27, 2018 Share Posted June 27, 2018 You might be able to use MOPs for this. The Explode modifier, with a shape falloff affecting a Transform modifier which acts on the individual primitive rotations. Quote Link to comment Share on other sites More sharing options...
dyei nightmare Posted June 27, 2018 Share Posted June 27, 2018 there are many techniques there... done in diferent ways most of them based on geometry solvers Quote Link to comment Share on other sites More sharing options...
