Atom Posted October 15, 2018 Share Posted October 15, 2018 (edited) Here is a basic setup for stitching vellum cloth together using the weld seams feature on the vellumdrape solver. Edge groups are assigned to the garment pattern pieces and define seams that will be stitched/welded. The edge groups are run through a subnet to produce companion point group for the edge groups. The point groups are used for stitching seams. The subnet allows you to increase or decrease the cloth resolution independent of these groups, so it is more like Marvelous Designer particle separation in that respect. The vellumdrape solver has been hacked to allow deforming collision geometry. All I did was disable the timeshift node which kept the deforming geometry locked to the start frame. ap_basic_vellum_drape_vest_101518.hiplcFetching info... Edited October 15, 2018 by Atom 2 Quote Link to comment Share on other sites More sharing options...
jason_slab Posted October 16, 2018 Share Posted October 16, 2018 Hi I made a simple adjustment to your setup based on what I think the drape workflow should be, I also reduced the cloth thickness as it was to large for the scale of this character. Js ap_basic_vellum_drape_vest_js.hipnc 1 Quote Link to comment Share on other sites More sharing options...
art3mis Posted January 8, 2019 Share Posted January 8, 2019 Thanks for sharing. Super useful! Have you ever been successful in layering clothes? ie more than 1 drape in a single network with at least 2 layers, 1 drape for layer 0 or undergarment and a 2nd drape for Layer 2 or overgarment. No matter what I try I either end up with a successful drape that won't animate, or clothing mesh that explodes when I try and animate. Quote Link to comment Share on other sites More sharing options...
Atom Posted January 8, 2019 Author Share Posted January 8, 2019 I have not, but if I were, I think I would just bake out the resulting first layer and then use that as a collision layer on another single layer drape. Have you checked out the Sara Rascon tutorials on SideFX? https://www.sidefx.com/tutorials/november-thug-vellum-with-sara-rascon/ 1 Quote Link to comment Share on other sites More sharing options...
Noobini Posted January 8, 2019 Share Posted January 8, 2019 10 layers...1 sim...in one go....default cloth, substeps 3......no, I didn't do anything clever....just works. Quote Link to comment Share on other sites More sharing options...
art3mis Posted January 9, 2019 Share Posted January 9, 2019 On 1/8/2019 at 10:14 PM, Atom said: I have not, but if I were, I think I would just bake out the resulting first layer and then use that as a collision layer on another single layer drape. Have you checked out the Sara Rascon tutorials on SideFX? https://www.sidefx.com/tutorials/november-thug-vellum-with-sara-rascon/ Expand Funny you should ask Yes have watched it now going on 3 times and have even tried replicating her network, albeit on a much simpler scale! There is something fundamental I am missing. She uses a PinToAnimation technique after a drape on the same network. Am going to continue trying to deconstruct her example to see where I am going wrong. Noobini, thanks but does each layer also have its own drape? Quote Link to comment Share on other sites More sharing options...
Noobini Posted January 9, 2019 Share Posted January 9, 2019 3 drapes, run cycle...works. Didn't even sim/bake lower layer then sim next layer above.....all 3 layers were simmed live against each other in one sim. Quote Link to comment Share on other sites More sharing options...
anim Posted January 9, 2019 Share Posted January 9, 2019 you should post a simple case of it not working as you are clearly talking about situation where the individual layers have a lot of attribs attached from previous Drapes and also maybe some unwanted constraints, so then obviously all that coming to a new Vellum Solver may cause issues if not cleaned properly Quote Link to comment Share on other sites More sharing options...
Noobini Posted January 9, 2019 Share Posted January 9, 2019 On 1/9/2019 at 3:21 AM, anim said: you should post a simple case of it not working as you are clearly talking about situation where the individual layers have a lot of attribs attached from previous Drapes and also maybe some unwanted constraints, so then obviously all that coming to a new Vellum Solver may cause issues if not cleaned properly Expand agree...and because the asker asks lots of questions yet is so precious about uploading his file...I'm not giving him my file. Have a look around, lots of ppl upload their files for others to study...yet the one asking for a lot of help won't upload his... Quote Link to comment Share on other sites More sharing options...
art3mis Posted January 9, 2019 Share Posted January 9, 2019 Thanks for the feedback! And no I have no problem uploading files which I do all the time. In this instance haven't had time to simplify my original file enough Attached is a bare bones example based on Atom's original file using my first 'naive' approach of simply merging the results of 2 drapes before feeding to a Vellum Solver. The result is the exploding geometry during the final solve. ap_basic_vellum_drape_vest_Layers.hipnc Quote Link to comment Share on other sites More sharing options...
anim Posted January 9, 2019 Share Posted January 9, 2019 ultimately it came down to your welding attributes not being correct after the merge, all is annotated inside the file ap_basic_vellum_drape_vest_Layers_fix.hipnc Quote Link to comment Share on other sites More sharing options...
Noobini Posted January 9, 2019 Share Posted January 9, 2019 (edited) did same...tho I don't know about wrangling so I just used a Vellum Weld, then also attached the top seams to shoulders so less likely to slip off during violent moves. So after merge1, you've got the geos of both vests....simply treat this as the 'initial state'. Pretend some modeller has finished his part and gave you the vests and tell you to sim. Then it's just a normal standard procedures, configure cloth, weld the precut panels...add any extra attach to geometry...sim... Edited January 10, 2019 by Noobini Quote Link to comment Share on other sites More sharing options...
art3mis Posted January 10, 2019 Share Posted January 10, 2019 (edited) Thanks so much guys!! After studying Sara Rascon's THUG presentation files for the flamenco dance I was convinced that the only solution was to use a PintoAnimation technique that she used after each draping process. However could not get it to work even after hours of trying! I did however learn a TON about proper Cloth Constraint settings...my very rough understanding of Bend Stiffness for instance is .1 = starched collar, .01 regular cotton blouse or shirt and .001-.005 for silk shirt or blouse. And to enable plasticity only for certain materials like denim. Edited January 10, 2019 by art3mis Quote Link to comment Share on other sites More sharing options...
anim Posted January 10, 2019 Share Posted January 10, 2019 On 1/10/2019 at 12:33 AM, art3mis said: my very rough understanding of Bend Stiffness for instance is .1 = starched collar, .01 regular cotton blouse or shirt and .001-.005 for silk shirt or blouse Expand just keep in mind that even if the solver has enough iterations to converge to set stiffness values, those values may only work on the cloth of certain resolution, if you use the same values for much denser cloth of the same size, you will get different feel from the material overall, less dense geometry will feel stiffer and vice versa, this can also cause issues for meshes that have nonuniform mesh density as the cloth "material" will not feel consistent Quote Link to comment Share on other sites More sharing options...
art3mis Posted January 10, 2019 Share Posted January 10, 2019 Thanks Never understood purpose of Weld Frame delay unless used in conjunction with Inflate Collisions. All the examples I’ve seen have the Weld delay set to frame 0 or sometimes 1. Quote Link to comment Share on other sites More sharing options...
anim Posted January 10, 2019 Share Posted January 10, 2019 On 1/10/2019 at 6:26 PM, art3mis said: Never understood purpose of Weld Frame delay unless used in conjunction with Inflate Collisions. Expand it doesn't have anything to do with Inflate Collisions it's simply a delay how many frames into the simulation the seams will be welded, until then seams are just pulled together with the stitch constraints so it's to allow for seams to get close enough so that the sudden snap from welding will not cause insane velocities and sudden penetrations as its more likely to happen if they snap from the beginning Quote Link to comment Share on other sites More sharing options...
