Scatter on geometry only on Y-Axis
sant0s81
Hello,
I am building a simple cave system.
The cave itself is a spline -> copy a circle to points -> skin it ->  and finaly bool the tunnel into a cube.
Now I would like to scatter points on the cave ceilling, to have anchor poitns for cables and lamps.
I attached an image to show what I mean.
I though, I could maybe use the exsiting spline and the upvector to somehow alow the points to scatter only on the ceilling - but I have totaly no idea how to do that.
Also about the cables - is there a tutorial, that shows something similar?
Like generating a spline between the points and give it gravity to let it hang down between the anchor points.
And another question is, if there is some way to erode the tunnel.
I guess, with HF Project I cannot modify the tunnels inside the box - is there another way to kinda fake erode?
Thx alot! :)
edit: I wanna create something like that: https://blog.csiro.au/kids-raid-caves-in-virtual-classroom/
So the points on the cave ceilling also could be used to create stalactites or on the floor a way system etc.
Edited by sant0s81
Hey,
thx for replyling!
One thing I forgot to mention - I wanna keep it procedural since I have to modify the curve / tunnel.
So it would be great, to not always group the geometry like in ur example @vicvvsh.
i thougth, I could for example just use the exsisting spline and transform it in the y-axis only until I am near the closest points of the tunnel.
Than use that spline (points of the spline), to generate a weight map on the tunnel geometry, that I can expand by distance to points, add a fractal to get more variation etc.
In Softimage I would just use the curve, move it up in the upvector, shrink wrap it to the geometry and than generate a weight map by distance to the spline points.
Thats what I try more or less in Houdini atm.
Thx again :)
Cheers
Edited by sant0s81
I wouldn't say that it not procedural because all groups created procedurally ... but it's up to you
Another example without a single group
P.S. there is one group actually )
scatter_on_top_02.hipnc
Edited by vicvvsh
Good morning,
thx u guys alot for these examples - lots of great input and super usefull.
I am gonna study them now.
In your example @vicvvsh I just added a fuse node to evenly snap and delete the points and already have the lamp setup - thx alot. :)
Cheers
