Masoud Posted March 28, 2019 Share Posted March 28, 2019 Hi; In Vellum , is it possible to change the shape of input geometry, over time? I have a line in my scene that grows (in length) over time, and I would like to use it in vellum-hair, but it seems that vellum just uses first frame. Thanks. Quote Link to comment Share on other sites More sharing options...
johner Posted March 28, 2019 Share Posted March 28, 2019 (edited) Yes, you want the Vellum Rest Blend DOP, which you can point at an external SOP that animates your rest geometry. It will update the rest state of a specific set of constraints based on the input Rest geometry. With 17.5 there is a help example for Vellum Rest Blend SOP that shows some uses of it. Attached is an example of lengthening hair curves over time. Note the rest topology has to match the original geometry, i.e. you can't add points, but you can transform them in various ways. grow_hair.hipFetching info... Edited March 28, 2019 by johner 2 Quote Link to comment Share on other sites More sharing options...
HM_2020 Posted November 20, 2019 Share Posted November 20, 2019 Any way to update topology? I am trying to carve out a curve>polywire, basically grow a shape over time along the curve and make it vellum cloth, live and waving as it grows. Seems like trying a sop in dops does not update it over time like you can with constraints. Cheers! Quote Link to comment Share on other sites More sharing options...
kerguestenen Posted February 13, 2020 Share Posted February 13, 2020 HI! Any success? Having the same question with the same carved line here Quote Link to comment Share on other sites More sharing options...
diffuse.gray Posted May 1, 2020 Share Posted May 1, 2020 To date, the only workaround I've found is loading in a bunch of extra points somewhere out of frame (i.e., hang onto a few hundred thousand points down at {0,-100,0} or something), and setting them to inactive. When you want to change your topology, swap them in and activate them. It's ugly, but it's the only thing I've managed to get working for a case where I wanted to resample under strain instead of breaking... Quote Link to comment Share on other sites More sharing options...
Noobini Posted May 1, 2020 Share Posted May 1, 2020 dunno if this is applicable to your scenario (or carve situation): https://zybrand.xyz/vellumcontinuous-emit-with-dynamic-constraints#more-324 I fooled around a bit to use hair instead of grains...mods were pretty minimal, you too can do it. 2 Quote Link to comment Share on other sites More sharing options...
Masoud Posted May 5, 2020 Author Share Posted May 5, 2020 Thanks everyone, good tips. Quote Link to comment Share on other sites More sharing options...
HM_2020 Posted October 27, 2021 Share Posted October 27, 2021 (edited) On 5/1/2020 at 10:37 PM, Noobini said: dunno if this is applicable to your scenario (or carve situation): https://zybrand.xyz/vellumcontinuous-emit-with-dynamic-constraints#more-324 I fooled around a bit to use hair instead of grains...mods were pretty minimal, you too can do it. Expand Nice one, mind showing the way? Edited October 27, 2021 by HM_2020 Quote Link to comment Share on other sites More sharing options...
Khikmatillo Posted June 4, 2022 Share Posted June 4, 2022 Hi, guys, I have a same problem,(sorry I don not share my geometry) my geometry topology is changing during the vellum sim, and result is very bad, how to make topology unchanged during sim, Please sahre your experince, Quote Link to comment Share on other sites More sharing options...
madebygeoff Posted June 5, 2022 Share Posted June 5, 2022 (edited) I hope this isn't belaboring the point, but the reason this is hard is because it is working against the main benefit of vellum. The whole idea behind vellum and position based dynamic solvers is that they affect the position of points directly without referencing internal forces. Let's see if I can not botch this explanation: but instead of calculating physically realistic forces like pressure, elasticity, volume preservation, etc., vellum represents a material as points and constraints. Those constraints just have stretch and bend limits as well as damping. Over a number of iterations, the solver then updates the position of each point in a way that best satisfies the limits of all the constraints attached to that point. It is not physically accurate, but the advantage of this is that it is very fast and is much more stable UNLESS... the topology changes. As soon as the topology changes the wrong constraints are matched to wrong points and all hell breaks loose. In order for vellum to work, you need to have each individual point retain the same point number throughout the simulation AND you need to have the constraints (your constraint geometry) keep the same point numbers and primitive numbers. So there's basically three ways (that I can think of) of doing this if you want to change the shape or size of a simulated object: 1. You can keep the same geometry and update the parameters of the constraints so that it appears as if the geometry is changing (like hair growing because the rest length is increasing over time, or a balloon inflating because the rest length of the pressure constraints are increasing, or cloth sagging because (you guessed it) the rest length of the stretch constraints are increasing over time. This is what John set up earlier in the thread. 2. You can perform the simulation on a stable piece of geometry and either alter it post-sim (for instance carve the piece of tape post-sim) or use it to drive a different piece of geo that is being altered (say transfer position based on UVs as an example). 3. Or finally you can get fancy and devise a way to keep the point numbers and constraint geometry from changing as the topology changes. HOW you do this depends on what kind of changes you are introducing to the topology. I'm not aware of a single set up that would work in all cases. But those are the conditions you have to meet if you want it to work... Edited June 5, 2022 by madebygeoff 1 Quote Link to comment Share on other sites More sharing options...
