Masoud Posted July 25, 2019 Share Posted July 25, 2019 Hi; Is there any tool to measure distance between two points in viewport? Thank. Quote Link to comment Share on other sites More sharing options...
andmotion Posted July 25, 2019 Share Posted July 25, 2019 Maybe measure SOP? Quote Link to comment Share on other sites More sharing options...
Masoud Posted July 25, 2019 Author Share Posted July 25, 2019 (edited) 3 hours ago, andmotion said: Maybe measure SOP? No, it's not what I need. I mean something like 3DS-Max Tape helper. https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/3DSMax-Basics/files/GUID-B2FAC5EC-2C6D-4BF0-859D-68F9ACBEFB43-htm.html Edited July 25, 2019 by Masoud Quote Link to comment Share on other sites More sharing options...
kleer001 Posted July 25, 2019 Share Posted July 25, 2019 (edited) Not out of the box, no you're not going to get a quick and snappy gui information like that. But it'd be easy enough to figure that out. Select the points in question in the viewport, delete everything else, create a line between them (add SOP), and then get its perimeter (measure SOP). Big plus is that you can then change geometry before that point and the length (permieter) will update down the chain as long as the point count doesn't change. But you could create groups in a clever way and those would be more robust. However, I would recommend building your setup in such a way that you don't need to know the distance between two points. That's veracular Houdini VERNACULAR! Gahhh. Edited July 26, 2019 by kleer001 Quote Link to comment Share on other sites More sharing options...
Sepu Posted July 25, 2019 Share Posted July 25, 2019 As Clear mentioned not out the box. However, you can do it yourself with python states https://www.sidefx.com/docs/houdini/hom/python_states.html or try this method from youtube Quote Link to comment Share on other sites More sharing options...
cudarsjanis Posted July 25, 2019 Share Posted July 25, 2019 3 hours ago, kleer001 said: veracular Houdini Veracular Houdini Quote Link to comment Share on other sites More sharing options...
Masoud Posted July 26, 2019 Author Share Posted July 26, 2019 Thank you guys. Houdini is awesome, but in sidefx, they like to make simple things so complicated..! Quote Link to comment Share on other sites More sharing options...
kleer001 Posted July 26, 2019 Share Posted July 26, 2019 19 hours ago, cudarsjanis said: Veracular Houdini NNNNNN! verNacular! Quote Link to comment Share on other sites More sharing options...
kleer001 Posted July 26, 2019 Share Posted July 26, 2019 1 hour ago, Masoud said: Thank you guys. Houdini is awesome, but in sidefx, they like to make simple things so complicated..! https://xkcd.com/1425/ 1 Quote Link to comment Share on other sites More sharing options...
cudarsjanis Posted July 26, 2019 Share Posted July 26, 2019 3 minutes ago, kleer001 said: NNNNNN! verNacular! ahh yes. Didn`t notice the typo and did it myself. Was just laughing about the joke 1 Quote Link to comment Share on other sites More sharing options...
