Librarian
Check this guy sites. it's a "Macro" photogrpher. Most of the incredible spider picture (include the mirror spider above) you can see over the web come from him.
First time I see some of his photography I thought for sure they were 3d pictures.
https://www.nickybay.com/
https://www.flickr.com/photos/nickadel/
Edited by flcc
On 19/2/2020 at 8:56 AM, Librarian said:
3 lesson.
(combining with tutorials from Hai Le and Matt Ebb) was to model something ..learned more about loft skin and normals, pretty much you can model everything just need to visualize (little bit forward)  :wub:
Hey, what tutorials have you seen? could you give more info on this please?
Colors  and motion(from particles(rotation(houdinifx.jp) a loot of examples for particles
code from ->Anastasia Opara (Creativity of Rules and Patterns)
Basically you need only to know to manipulate colors (gradient) endless possibility.. I use H16.5
//get all gravity points
int pc [] =pcfind (1, "P", @P, ch("dist"),100);
//account direction
vector gravity_vec = {0,0,0};
foreach (int p; pc)
     vector pos = point (1,"P", p);
     float mass = point (1,"mass", p);
     float dist = fit ( distance (@P,pos) , 0, 10,0,10);
     //float dist = clamp(distance( @P,pos), ch("min_dist"),1000);
     vector dir = normalize (pos - @P);
     float str = clamp(mass /pow (dist,2),0,ch("max"));
     gravity_vec += dir * str *ch("gravityconstatnt");
 @N= gravity_vec;
 @pull = length (@N);
//account direction
foreach (int p; pc)
     float str = clamp(mass *pow (dist,2),0,ch("max_pull"));
 @N= gravity_vec;
I've done this tutorial (hai le) but don't have succes with it. Just get circles, not hexagons.
I am bumped my head on this,  checked each character in this code, but no way.
I've get another method to make squared shapes but different flavor.
I would be really curious to find what's Wrong.
is it possible you post the working code ?
@flcc mine Bad that I do not do formulation in a better way.:huh:
tutorials.cgrecord.net/2019/08/hexagon-in-houdini-vex-tutorial-by-hai.html
plus for lazy people  tutorial he did recently ( best tutorial for million different stuff)..just love people that share knowledge :wub:
I just use those tutorials because I have unlimited possibilities to have Contour(posted that file )  also different shapes that I can easily export for CNC machining ...
PatTOdforce.hipnc
Edited by Librarian
